DONT STAY LURKING AS A GUEST,
CLICK HERE TO JOIN.
Countdown To Christmas!
  • 0
Fire Alarm - Certification
matt.leung
Question
matt.leung
can i just confirm that installing a fire alarm in a domestic property would come under a minor work certificate, as i will be taking the power from a non RCD protected lighting circuit.
Because it is a fire alarm i just wanted check the certification...
Link to comment
7 answers to this question
MWC or Minor Works Certifcate sounds good to me :D
Link to comment
calltronics
BS 5873 or the equivalent ISO whatever
Says the fire alarm should have its own dedicated supply!
Link to comment
Andy™
and in homes its common practice to use a lighting circuit. if your lights go off, you get them repaired quickly. if its the alarm circuit, it may go unnoticed
Link to comment
but if battery backed up then it would start bleeping ;) plus the lights wouldnt be steady on lit :P:coat
Link to comment
Andy™
but if the battery was not connected...
(unlikely, but could be missed on installation etc)
Link to comment
SPECIAL LOCATION
are we talking smoke or fire alarms
That would be my question also?
Link to comment
Archived
  • Create New...
