mcgaw81 Well-known member Joined Feb 14, 2008 Messages 576 Reaction score 0 Aug 7, 2009 #1 Has anyone installed or came across these heaters, What are they like to fit.
batty Snoopy™ Supporting Member Joined Feb 27, 2008 Messages 11,018 Reaction score 0 Aug 7, 2009 #2 No harder than other storage heaters but you need two supplies on and off peak. Fitted a couple and seemed ok to fit. Batty
a1 Forum Founder Joined Feb 6, 2008 Messages 10,185 Reaction score -1 Aug 8, 2009 #3 From our sponsors - Have a lok to see if there is anything on there... http://www.alertelectrical.com/Electric-Heating-Fixed/Dual-Heat-Heaters/default.asp
a1 Forum Founder Joined Feb 6, 2008 Messages 10,185 Reaction score -1 Aug 8, 2009 #4 Sorry McGaw - Try this link... http://www.alertelectrical.com/Electric-Heating-Fixed/Dual-Heat-Heaters/Dimplex-DuoHeat-Radiator-with-Electronic-Control---07kW-Output-DIMDUO300N.asp
wozz Distinguished Member Joined Jan 1, 2009 Messages 2,217 Reaction score 1 Location Kent Aug 8, 2009 #5 fitted them pretty straight foward the only problem is isolating all the supplies, if your using a controller you have to isolate 3 supplies or 5 poles depending on how you are looking at it.
