DONT STAY LURKING AS A GUEST,
CLICK HERE TO JOIN.
  • 0
Smoke Alarm distance from wall/light fitting
Jono Pashley
Question
Tomorrow i have to go drop all the cables down through the new suspended ceiling on the job im at, but in the hall the drawings show the light fitting(2D bulkhead type thing) and smoke alarm(mains) quite close together and im sure i need minimum separation between the wall and the detector and also between the detector and the light. Can anyone shed some light on this as i dont have much room to play with in this hall
Cheers Jono.
Link to comment
5 answers to this question
Should be stated on the manufactures instructions for the smokes, but I think you will find Theoryspark is correct
Link to comment
cheers for that, i asked for the spec on the detector today so i could look the manufacturers instructions up but as usual no response.
Link to comment
Theorysparky's right its 300mm away from walls and light fittings.
Link to comment
300mm away from anything that could affect the airflow to the sensor..
Link to comment
Archived
  • Create New...
