DONT STAY LURKING AS A GUEST,
CLICK HERE TO JOIN.
  • 0
17th Ed CU
adyver
Question
Guiness Drink I am about to upgrade an old CU to a 17th Ed Dual split box. Between the existing CU and meter there is a 100amp Wylex Dp switch and fuse. (Makes it very easy to change the CU). In order to comply with the 17th Ed is the Wylex Dp Sw sufficient or does the CU also need to have a 100amp Dp switch incorporated.
Can anyone recommend a dual split box which will take 16 or more MCB's, without going daft my supplier only stocks Mk and Wylex up to 14 ways?. Guiness Drink Guiness Drink Guiness Drink
Link to comment
4 answers to this question
you will still need a 100a DP switch incorporated within the new consumer unit.
mk sell a 16 and 21 way module unit.
these are the model numbers for each
16 way - k5516s
21 way - k5521s these are the ref codes from my local wholesaler...
Link to comment
a dual split has a 100A isolator.
Wylex do a 15 way board, and im sure they will have something larger
Link to comment
Archived
  • Create New...
