Creative or just lazy?
Aug 5, 2014
8,669
1,286
Woking
Took a cover off a CU this morning to see if there was a "cooker" circuit!
I'm assuming that the installer couldn't be bothered to investigate issues and made these unusual changes ............  think it'll be added to the work I may be doing
But surely if you know there are issues with circuits wouldn't you just raise them with the client and agree a rate to investigate and fix them?
My guess: the installer C***** up and cut both busbars too short, then thought, how can I correct it?
What's going on in picture 2?  the new L strapper seems to have had a haircut with a couple of strands into L and a loose strand perilously close to the N?
I've seen socket and lighting circuits crossed with each other on conservatory alterations...
Live from a light switch..
but neutral taken from the sockets..
as switch only had Live & switched live..
Or other downstairs light alterations joined onto upstairs socket neutrals...
as DIY-bob couldn't find the correct circuit cables when messing under floorboards..
especially when lighting is wired in singles!!
:popcorn
Given the CU install is only 18 months ago I asked the customer if they had an EIC ....... and yes they did
This is the relevant part
Not sure I would have considered the CU install complete with those issues on the EIC
