DONT STAY LURKING AS A GUEST,
CLICK HERE TO JOIN.
  • 0
outdoor lights?
derek13
Question
evening all am thinking of installing a pir security light outside and thought i would get your views the plan is to come off the upstairs lighting circuit with twin and earth drill through at highish level and fix the light? is twin and earth ok to run outside for a very short length ??ps will be drilling through the loft.
cheers for ur help;)
Link to comment
20 answers to this question
T&E quite commonly used outside but does degrade in UV light over time.
Link to comment
that would work however you might want to install a fused spur switch with 3A fuse, easily accessed from just inside loft hatch for when you have to change the lamp
not required but would make for a better job
i.e. 1.0/1.5mm t&e from upstairs light to fused spur to pir light
Link to comment
good point do outdoor security lights often trip that circuit through water etc being outdoor that concerns me? and would the installation of a 3 amp unswitched fused spur take that risk away i.e. only trip the fuse spur 3 amp fuse??
thanks very much again
Link to comment
you should use a DP switch for outside light. if water gets in and trips RCD, a SP switch may not disconnect fault until it can be repaired
Link to comment
yes, but make sure its DP. some are only SP. or if its from a lighting circuit, you dont need a fuse in it
Link to comment
depends on what you have in the consumer unit
old style rewirable fuses and the 3A fuse should blow first
newer style mcb's and the mcb will trip before the 3A fuse
that wasnt the reason for suggesting it, more because you would have to turn off the whole lighting circuit should any work be needed on the new light, which might not sound to bad but then imagine your up the ladder messing on with light and someone comes home, finds the light in the bathroom wont work and realises the trip thingys down, switches it up and....
this has recently been reported to have happened to a young plumber, he had turned off mcb under the stairs and went into loft to do some wiring work only for the old lady in the house to turn the mcb back on..... killing him
Link to comment
shows the need for a lock on the MCB!
Link to comment
thanks guys just a quick question why if new style mcb is fitted why will that blow before 3 amp in fused spurr ??? thanks again for ur help
Link to comment
very true but how many sparks actually own/use one domestically
never mind other trades....
Link to comment
let through current of an MCB can be less than whats needed to blow a fuse of a lower rating
Link to comment
the house has new style mcbs at the board so i take it that if water does get into the light etc the mcb is still likely to take the upstairs circuit out anyway?even if its installed from light to switched fused spurr to outdoor light?????
cheers
Link to comment
water is more likely to trip an RCD. you will need something DP otherwise a N-E short will not be isolated with a SP switch, so your RCD wont re-set
Link to comment
cheers andy just to get your opinion would u be happy to install the light -light-switched fused spurr-outside light ?? just wanna be extra sure !!
thanks
Link to comment
i would use a DP switch of DP fused spur from lighting circuit then cable to outside light
Link to comment
Hi Andy , must say ive never come across a single pole F.S.C.U ...you learn something every day....what manufacture are these then...surely they must all conform to the same B.S ?
Link to comment
Link to comment
Archived
  • Create New...
