DONT STAY LURKING AS A GUEST,
CLICK HERE TO JOIN.
Incoming cable to cut out taped up
Blue Fox
Been to look at a job and found the cores of the cut out cable are taped up with black insulation tape! THe seals on the cutout are fully intanct and there is no realistic way it could have been taped in place. Do you think I need to get customer to call supplier to get this corrected once I'm finished - going to be do c/u change.
Link to comment
If it looks dangerous in any way, contact DNO on their emergency number
Link to comment
I have seen this loads of times.. and I have seen it done,, usually on straight or split con
Link to comment
its a method defo used day in day out on the neutral of hybrid cables its part of the guide set out for there termination. As nozspark said see it used all of the time. If in any dought of the safety of the cable just give DNO a call.
sparkss
Link to comment
Archived
  • Create New...
