DONT STAY LURKING AS A GUEST,
CLICK HERE TO JOIN.
Countdown To Christmas!
  • 0
PIR'S
derek13
Question
excuse my ignorance people have recently purchased a pir motion sensor outdoor light , the light i was replacing already had a switch so new light also works off a switch . am i right in thinking the light should also work when switch is off i.e when motion is detected ????? as this does not seem to be happening only working when switched on at the min
thankyou for any replies
Link to comment
16 answers to this question
matt.leung
the switch will still control the lighting circuit, think about the route the current is going to take from the supply to the light...
Link to comment
thanks for reply so the light needs to stay switched on in order for the pir to work even though it has the motion sensor ????
thanks again
Link to comment
Andy™
thanks again
im assuming this switch is inside the house? if so, then unless its turned on, then you light will have no power, so cannot possibly work
Link to comment
yeh it is mate and of course makes sense in other words it needs a permanent live to work unswitched ?? again thanks for help
Link to comment
maccarooni
Had one once batty where the light needed a permanent supply aswell as switched override. Old dear had gotten John Wayne Himself to do it I think. She rang to ask could i look at it as it never seemed to come on during the evening unless she flicked the switch but she thinks it comes on overnight. John had promised her faithfully that it was the fitting she had supplied. When i opened up fitting, it had 1mm T+E fron switch plus a seperate SINGLE 2.5mm BLACK connected to the light. Went into loft and followed said black single almost 5 Mtrs to a 30A JB. Which was feeding a couple of nightstores..
how could anyone believe this was acceptable...............
headbang
Link to comment
SPECIAL LOCATION
headbang
I am not going to tell you again maccarooni!.....:|
If you keep going round putting my work right I will go and tell the Don to come and sort you out!X(X(X(X(
Admin! maccarooni keeps picking on my work.....
Tell him he's been naughty again....
its not fair:_|:_|:_|:_|
Link to comment
Morris! maccarooni keeps picking on my work.....
The main Administrator is now known as Morris
:D
Link to comment
Apache
But you don't want to do that do you? Nice to turn it off when changing the bulb etc....
Link to comment
yeh exactly mate thing is got a small dog runs out last thing at nite cant see the little muppet ha ha so wanna put a pir in with motion sensor so it will pick dog up without me having to stand outside all the time watching over it but then again like u say problem changing bulbs etc
Link to comment
Andy™
If you want to see your dog and it doesnt pick him up, flick the switch on and off twice and it will stay on.
on many lights its turn off then on for permanent and turn off for 10 sec then on for back to PIR
Link to comment
yes u need to keep the switch turned on inorder to get power to the light for the pir to work all the pir is, is a switch
Link to comment
Link to comment
At least, on those units provided with over-ride ;)
Link to comment
To have the option of switching light on permanently you need 3 cores and earth or do it the way an idiot had done on a job I put right at the weekend and had used the cpc as the switched live. Or as others have said some lights have the option to overide by switching on off quickly.
Batty
Link to comment
Archived
  • Create New...
