DONT STAY LURKING AS A GUEST,
CLICK HERE TO JOIN.
new builds... plasterers are *******
Guest Dane
lets see..
is it just me this happens to???
Spot the light switch
Picture 1
only just there still....
Picture 2
Spot the light switch game again :)
Picture 3
FOUND IT.... ******s
Picture 4
Picture 5
another "spot" this time the light fitting cable that was left hanging down!!!
picture 7
SOME plasterers need to start and bloody be reasonable. or il take hammer to it next time!
Link to comment
i have had the same thing today... had to try and find them, not very happy as now the customer think i am **** as there is a bit of patching to do~!!
Link to comment
last job i done, i made a note of measurements to every downlight. gets there for second fix, and one hole is there. fortunately, all measurements found where they should have been and were within 20mm... all sockets/switches plastered over, but still visible. on most jobs the plasterer has to return to make good the holes ive made whilst trying to find stuff thats been lost... and they still dont get the hint
Link to comment
I am most interested in picture 6...............
:D
Link to comment
:D
so am i
Link to comment
typed 7 instead of 6 haha sorry guys... no filth there.
Andy ive got all measurements, so not a problem, i got pictures before, measurements for every room, same for switchs got notes for where they all are,
but it sure is a **** take
The plasterer wont be returning... hes told him no more work for taking ****
the best one, no picture yet...
All CU cables were cut down by plastered and tucked into friggin wall.
Link to comment
even if they are long enough, you can guarantee there wont be any markings on them
If any plasterer done that to me, they would be gettin an invoice for extending each cables and ID'ing them
Link to comment
i always leave 24" out of wall, bit much but "just incase"
they have been shortened to 12" so i MAY get away with it.
All tags, i put right up 2" from wall so there still there thank god
Link to comment
just as well. all my markings on everything consist of nicks to the end of the cable. cut that off, and there goes the marking
Link to comment
What you describe and what I have seen from the pictures is just normal practice I am afraid.
I once did a job where the walls where re done in mortar than plastered over.
The only way I found any of my cables and backboxes was because I always use the same measurements for heights and record kitchen designs etc.
My apprentice can pull cables out of 80mm of plaster without a scratch on the sheaths, thats how often we have to do it.
Link to comment
Calm down fellas not all plasterers are ******* I'm a plasterer and most sparkys say tuck the cable up for spots and they cut them out after, theres no point me cutting the holes cus I haven't got the drawings, I don't know where they go. I know 1 plasterer if he doesn't get on with the sparky he cuts cables and fills boxes, he's a d**k.
Link to comment
No he's a wa...er.
Link to comment
So tell me..
what is hard about cutting around the plaster board where sockets and stuff are? there are 7 ive got to do like this... they have 25mm box's on so shouldnt be an issue!!! but no instead, then moved the plaster board further away from wall to go STRAIT OVER THEM
Normal practice, so its normal practice for a plasterer to full the whole back box with skimmin compound? not just upto it and leave a little hole showing? These are the first plasterers that have ever done this, all the others have been sound and no problems at all
The plasterer wont like my self today and the site forman/owner.. as the words were
"if you damage anything, he pays (hes not been paid yet)" :)
Link to comment
As was said already this is normal stuff
I like to clean my own boxes out because the plasters normally damages the lugs
I wouldn't go ****ging other trades off to anyone because you may be on another job with that bloke and he could make your life hell, and also its not professional (have a quite word in his ear works)
Link to comment
He is the FIRST plasterer i have come across that thinks its wise to FILL the boxs behind cable, cake them in completely.
So its not really common and normal stuff.
Not ****gnig a trade off at all... im showing pictures of what a mess a plasterer has made
Is it also common practise and "normal stuff" then to cut cables?
plaster board STRAIT OVER sockets? yes PLASTER BOARD thats a 25mm box on the wall... and board strait over it. 25mm dot and dab? Since when? last i knew it was on average 12 - 15mm not 25mm lol
Link to comment
I always put some Insulation tape over/around them.
Link to comment
The size of the dabs depend on the condition of the wall. If the walls out then the dabs need to be bigger to get the boards straight. A 25mm dab is fine in fact fairly standard.
Link to comment
new build.. walls are spot on from my measurements and joiners measurements.
Link to comment
just because its a new build doesn't mean the block work will be bang on. You wanna see some of the stuff I've had to get over.
When you measure 3 or 4 times, for certain reason, and the measurements are spot on and the walls are far from out.
I dont think it gives an excuse at all for filling a box with plaster! on purpose, i can understand a slight amount
But for me to have to DIG a cable out its not how it works.
Ive done MANY new builds, renovations etc and never had this problem ever.
So its not normal or common practise
Link to comment
Next time you're on a job with him, cut the lead off his mixer drill -for a laugh
Link to comment
bend a peice of cardboard into your boxes once your done, it protects your cables and if you get a good bend on it, it will protrude slightly so the plasterer cant go over the box.
Link to comment
and they would just remove it strait away.
Link to comment
Archived
  • Create New...
