DONT STAY LURKING AS A GUEST,
CLICK HERE TO JOIN.
Countdown To Christmas!
  • 0
10.8kw showers
sellers
Question
whats the deal with them, why do you need such a high powered shower?
Going to do a job this weekend and the customer has already bought the shower. I'm wiring it and a new cu change. Surely this is going to take a 50amp mcb 10800/230= 46.9A will a 10mm T+E manage this located in a wall.
Link to comment
6 answers to this question
matt.leung
ur gonna have fun this weekend.. good luck mate..
Link to comment
Revved Up Sparky
I cannot remember the correction factors from memory but I think that a 10mm T&E will be fine protected by a 50A MCB on an RCD protected board.
You could always run 16mm T&E if you're still worried but I think you would have a nervous breakdown trying to wire the pull cord isolation switch with 16mm ends !. 10mm is fiddly enough !.
Link to comment
Crabtree pullswitch but 10mm should be adequate unless its a mansion or heavily insulated
Link to comment
green-hornet
Those crabtree pull switches are brilliant, and so easy to terminate 10mm cable into.
Link to comment
Andy™
unless its got a long run or lots of insulation, 10mm
Link to comment
Archived
  • Create New...
