DONT STAY LURKING AS A GUEST,
CLICK HERE TO JOIN.
  • 0
fasta fix boxes
derek13
Question
been putting a light in today, have to say placing a single fasta fix box was hard work but through my own fault i placed it at the side of an existing switch which left me with the problem of hitting the noggin on the other side of where the original switch is placed anyone had these problems and how to get around them?? obviously i didnt move the switch far enough past the noggin:_|:_|
Link to comment
21 answers to this question
Oh dear, Do you think TV will improve when we get a second channel .
Only when we get colour.:)
ROTFWL
Link to comment
cut the flange off and screw the box to the side of the nogging
I agree this is the only way to do it sometimes.
I was around when Noggin the nogg was on but far too young to remember it(cough)
Damn I spelt it right now its been blownROTFWL
Link to comment
Anyone heard of those plasma screen TV's? so far it only works in blue, but you never know, it may work in future
Link to comment
Do you mean dry line box???
Surely if you cut the "flange" off then you have nothing to attach the switch to on one side..
I drill a bit of the stud out [very carefully]
Link to comment
Noz - if you recess into the noggin then you could screw directly into that?
Link to comment
Sorry I got the wrong end of the stick,,, I thought that Derek was putting the box up against the side of the stud,, not on top of!! Oooops
Link to comment
if you cut the flange off a dry liner, you can then hold into place and put a screw through plastic into the wood. either make a small hole first, or go at it with a cordless screwdriver & screw
Link to comment
For older Forum members, would that be Noggin the Nog?:D
Sorry I'm far too young to remember Noggin the Nogg .Was he before Fireball XL5 or after Thunderbirds are Go ?
Link to comment
Well before either. I think it was in b & w & & about the same time as Capt. Pugwash.
Link to comment
Ah ! Sometime between Prudence Kitten and The Flowerpot Men then .
Link to comment
When you cut the "flange" off, you are still left with the screw entry for the plate switch.
You are only cutting off the part that clamps the plasterboard, you leave a small amount behind so that the screw will clamp.
The box is screwed to the noggin and hols it secure on that side whilst the other side is clamped by the normal procedure.
Link to comment
Yes they certainly were , I wonder which is best sometimes. Kids don't seem to be given time to be children these days.
Cor blimey !! you must be as ancient as me. You'll be saying you watched Roy Rogers & Trigger at the Saturday morning cinema next.
Link to comment
Hopalong Cassidy, Ivanhoe with Roger Moore, Torchy, Twizzle.
Link to comment
Rag Tag and Bobtail, Champion the Wonder Horse, Circus Boy, Bleep and Booster, Banana Splits - don't remember them either
Link to comment
Link to comment
Archived
  • Create New...
