  • 0
DIY GUY
Exterior lights
Question
DIY GUY
Hi I have a pir lantern at my front door I’m going to replace this with new lantern with dusk till dawn bulb. Down the line I plan on fitting another side light at my bins and also 2 up/down lights at the back patio door one at each side and possibly 4 decorative spike lights within the garden. Ideally I’d like every light to come on at the same time and all to go off at the same time, (dusk till dawn). All lights bulbs will be LED & below 10w. Is this possible to do and what would be the best way to do it, if not what else would yous recommend.
Share this post
Link to post
  • 0
Geoff1946
To achieve your aim to switch them all together I would go for a separate photo-switch wired back to a central point, maybe by your consumer unit, then radial distribution circuits to the various light locations.
It can't be done with a dawn-to-dusk bulb.
The "spike" lights I would recommend as low voltage with their transformer indoors.
Share this post
Link to post
  • 0
binky
i've always regarded lighting the whole exterior at the same time as a bad idea.
Share this post
Link to post
  • 0
DIY GUY
Why Binky? Do you have any other ideas how it would work best and what I’m best to do.
Cheers
Share this post
Link to post
  • 0
DIY GUY
Hi if you don’t mind could you explain a little bit more how I would achieve this please?
Share this post
Link to post
  • 0
binky
Cheers
Simples, if you are sat out on the patio, do you really want the lights on by the bins or the front of house. It's also more relaible to have independent lighting systems, and you have the problem of linking all the external lighting on 1 circuit. That means you either have to run a lot of cables through the house, or run something like conduit around the outside, which can be rather unsightly.
Share this post
Link to post
  • 0
DIY GUY
Tbh I wouldn’t mind my front light or side light on as I’m sat at the back of my house. My choice would be not to link and run cables on the outside walls. Atm I do have access to under the bottom landing floor boards and top landing floor boards and the attic. Do you have any suggestions/advice for linking from my lighting circuit and the best route to take.
Share this post
Link to post
  • 0
Murdoch
Thing with garden lights is that they WILL start tripping your RCD sooner or later.
unless a design considers this fault finding is tedious and expensive
Share this post
Link to post
  • 0
kerching
Last garden lighting job I did I ran 6 radials all isolated at garage ( source end) with 20A DP switches. Each radio can be isolated independently
just saying
Share this post
Link to post
  • 0
Phoenix
Just incase (C)rap music comes on?
Share this post
Link to post
  • 0
DIY GUY
So if I do away with the garden lights for now.  Could I easily run 4 low watt LED lamps from a photocell linking from a live at my lighting circuit?
Tanks
Share this post
Link to post
  • 0
Geoff1946
No  reason why not. I do endorse the recommendation to have an isolation switch in case of future faults.
A large proportion of household lighting faults are caused by moisture ingress into outside light fittings.
Being able to isolate the outside wiring means the rest of the house lights can still be used and also eases fault finding.
Share this post
Link to post
  • 0
DIY GUY
  • 0
Geoff1946
Between the two. The big 4 pole rotary is overkill, the single pole light switch inadequate because it doesn't break the neutral. (Isolate means breaking live and neutral)
You can buy a normal sized switch which is double pole.
https://www.screwfix.com/p/mk-logic-plus-20a-1-gang-dp-control-switch-white/44956
Edited by Geoff1946
Share this post
Link to post
  • 0
kerching
Mr Merlot assisted with the spelling
Share this post
Link to post
  • 0
DIY GUY
Would you recommend installing the isolation switch near consumer unit?
Would I link from a near by switch live onto this isolation switch with 1.5m t&e
Then from isolation switch onto photocell with 1.5m 3core&E
Then from photocell daisy chain my 4 lights out?
Share this post
Link to post
  • 0
Fleeting
The sensor will also require a neutral. If this is a dwelling additional 30ma rcd protection is also required.
Share this post
Link to post
  • 0
DIY GUY
My sensor has a N and I’ll be running 3core&E to sensor. My whole consumer unit is rcd protected
Share this post
Link to post
  • 0
BorisJ
No point in trying to light up the sky. Use downlighters.
Share this post
Link to post
  • 0
Sharpend
Other than decorative, I see little point in Up/Down lighters, either you light a brick or two above the light or you can see you feet when stood close to it, is not the point and purpose of a light, to light up all that’s around it? So guests can be seen or do people identify their guests by their shoes?
Share this post
Link to post
  • 0
DIY GUY
Each to there own I suppose, but I wasn’t looking for advice on what type of lights to use.
Share this post
Link to post
  • 0
DIY GUY
Decorative plus security is what I’m after tbh with lights being on from dusk till dawn.
Share this post
Link to post
  • 0
Fleeting
Does the nearby switch have a neutral.
Share this post
Link to post
  • 0
DIY GUY
Yes
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
