DONT STAY LURKING AS A GUEST,
CLICK HERE TO JOIN.
Countdown To Christmas!
  • 0
Hager bs number
D Brennan
Question
D Brennan
anyone know the correct BS number for a Hager 100a main switch from a 17 edition dual RCD CU, it has no markings on.
Link to comment
7 answers to this question
SPECIAL LOCATION
no good if you dont read the instructions either
even worse if you cant read;\:(
Give me Pictures (like on IKEA instructions)
No words just pictures!!!!!!!]:):P:p:p
:^O:^O
Link to comment
SPECIAL LOCATION
I suspect it should be compliant with BS EN 60947-3 ?
ref appendix 2 page 236 big red book.
and so as to comply with 537.1.1 & table 53.2
pages 116 & 117.
But you could alway check on Hager's own websites for some spec sheet info?
Link to comment
Brian 157
As Special Location says a DP main switch should be BSEN60947-3, if it's an RCD it should be BSEN61008
Link to comment
All hager bs numbers are on the info sheet that comes with the DB, no use if you didnt fit it I know but for future ref.
Link to comment
Andy™
Link to comment
Andy™
Instructions what are they.
its for when it doesnt work and all else fails and youve already wasted a minimum of 2 hours, then you can RTFM and be done in 5 mins
Link to comment
Archived
  • Create New...
