Hager bs number
D Brennan
Sep 22, 2008
415
anyone know the correct BS number for a Hager 100a main switch from a 17 edition dual RCD CU, it has no markings on.
I suspect it should be compliant with BS EN 60947-3 ?
ref appendix 2 page 236 big red book.
and so as to comply with 537.1.1 & table 53.2
pages 116 & 117.
But you could alway check on Hager's own websites for some spec sheet info?
As Special Location says a DP main switch should be BSEN60947-3, if it's an RCD it should be BSEN61008
All hager bs numbers are on the info sheet that comes with the DB, no use if you didnt fit it I know but for future ref.
