Sign in to follow this
Social Integrator
Voltimum - PowerBreaker Circuit Protection: Consumer Units & Socket RCDs
Social Integrator
Teaser text:
As experts in the field of Circuit Protection, the PowerBreaker brand has been synonymous with quality and safety for many years. We can now offer a complete circuit protection range to cover all of your electrical safety requirements with our new range of Consumer Units and our market leading range of RCD sockets.
PDF to HTML:
a:36:{i:0;s:87:" CIRCUIT PROTECTIONConsumer Units & Socket RCDsDesigned and Manufactured by";i:1;s:1472:"2Sales Tel: 01279 772772 Email: sales@greenbrook.co.uk As experts in the field of Circuit Protection, the PowerBreaker brand has been synonymous with quality and safety for many years. We can now offer a complete circuit protection range to cover all of your electrical safety requirements with our new range of Consumer Units and our market leading range of RCD sockets.The Consumer Unit range, which has been manufactured using the same high quality components and materials as you would expect from a brand like PowerBreaker, consists of fully or part populated units and a selection of modules and accessories with thoughtful features to ensure an easy installation. You can be confident of a quality product to fit the configuration you need for a reliable installation in any residential or small commercial environment. PowerBreaker - you can’t beat our experience so we really are the safest bet...● 18th Edition Compliant● Stylish, functional metal enclosures● Pre-assembled and split load options● Enclosures for configuration on site● Top Hinged Door● Increased cabling space● Large clear knockouts● Type A RCDs & RCBOs● Surge Protection● Clear labelling kit● High Integrity Boards● Built-in spirit level● Clean White Colour (RAL 9003)● 3 Year Guarantee● Third party Type Tested to BS EN 61439-3● 6kA Rated (Short Circuit Capacity)It’s a safe bet...Features & benefits...";i:2;s:511:"3Sales Tel: 01279 772772 website: www.greenbrook.co.uk Consumer Units Page NoDual Fully Populated Consumer Units10Dual Consumer Units with Type 2 SPD12Dual High Integrity Consumer Unit with Type 2 SPD14Consumer Units with Main Switch16Shower Consumer Unit15Garage Consumer Unit15Module UnitsPage NoSPD - Type 219Mains Isolator Switch Range20MCB Range21RCCB Range22RCBO Range23Consumer Unit AccessoriesPage NoCable Clamp18Bus Bars18Oval Module Knockout Guide18Blanking Plates & Label Kit18Contents";i:3;s:1033:"Combi-head screwsTorque Rating LabelKeyhole fixing to cope with uneven surfacesOption to mount incoming cable clamp to the DIN Rail to reduce cable stress at connection point (use code PBCC)Colour coded earth and neutral for ease of wiringBuilt-in, removable spirit levelVisibility of cables through terminal bar ensuring correct insertion and terminationIncreased wiring space at side, top, bottom & behind the busbar of unit to ensure trou-ble free installationFloating busbarWe offer Type A RCDs, MCBs, RCBOs and SPDs - all the protection options you will require Suitable for single phase loads with electronic componentsEasily Removable DIN Rail with supporting T BarFire retardant metal casingLarge cable entries positioned at the rear and both sides to provide maximum flexibility for wiring.+ Enclosure Impact Rating: IK 05+ IP Rating: IPX4+ Colour: RAL 9003+ Conforms to: BS EN 61439-3+ Earthed Lid+ 6kA Rated Short Circuit CapacityFeatures & benefits...4Sales Tel: 01279 772772 Email: sales@greenbrook.co.uk ";i:4;s:2227:"Surge Protection Devices- Use of an SPD reduces the risk of damage from atmospheric surges (lightning strikes) to connected electrical equipment- Every electrical device on a current can be destroyed by a LEMP (lightning electro magnetic pulse) on an unprotected circuit- SPD protects internal/external wiring infrastructure including sensitive equipment (TVs, computers)- Prevents unnecessary disruptionType A RCDs- Compliant with BS7671 Amendment 3- For circuits with luminaires within domestic premises, additional protection is required by an RCD with a rated residual operating current not exceeding 30mA this shall be provided for AC final circuits supplying luminaires18th Edition Wiring RegulationsThe Consumer Unit is the most important electrical safety device in the home as it protects life from electric shock but also protects against overloads which can result in electrical fires and damage to equipment.To comply to the latest wiring regulations, the new PowerBreaker range hasMetal Enclosures - The regulations state that enclosures are designed to encase a fire within it and restrict the fire spreading. PowerBreaker enclosures are manufactured from non-combustible steel and comply with BS EN 61439-3.Lighting Circuits - The additional protection of a 30mA RCD is now required on all lighting circuits in a domestic property.Knockouts - wide selection of 20,25,32mm and large oval knockouts for rear entry making the boards easy to install and adaptable for any type of installation.Surge Protection - PowerBreaker SPD boards have built-in Type 2 surge protection devices which prevent over-voltages in electrical circuits that can potentially damage electronic equipment such as TV’s, computers, washing machines, alarms etc.Type A RCDs - PowerBreaker offer Type A RCDs that detect pulsating DC residual currents in addition to the detection characteristics of Type AC RCDs. In modern households the goods connected to the consumer unit will be electronic equipment such as LEDs TV’s, multi-media systems, laptops, EV chargers etc which if at fault can cause a rush of DC current into the circuit.5Sales Tel: 01279 772772 website: www.greenbrook.co.uk ";i:5;s:3152:"Sales Tel: 01279 772772 Email: sales@greenbrook.co.uk 6Does your installation need an SPD?Surge Protection Devices protect against two forms of surge:-LEMP - Lightning Electro Magnetic Pulse (atmospheric surge)SEMP - Switching Electro Magnetic Pulse (industrial surge - more common e.g. blown fuse)Surges are transient over-voltages in a short time duration (often described as power surges or spikes) that increase the voltage measured between two or more conductors. (For a mains power supply, these conductors would be the line, neutral and earth). These surges can primarily result in serious injury to people but can also damage expensive items of electrical equipment which are now commonplace in our everyday lives. They can also create serious inconveniences such as loss of data should storage devices be damaged or in commercial installations, an interruption to the working day (i.e. downtime in workshops or offices).SPDs work by diverting the surge currents to earth to reduce the over-voltage to a level that will not damage the components of the system or equipment connected to it. There are three types of surge protection device:Types of Surge Protection DeviceTYPE 1 SPDThis SPD is designed to provide protection against surges caused by direct lightning strokes. This SPD is recommended in the specific case of service-sector and industrial buildings that have a lightning protection system or meshed cage. These can handle very high voltages by creating a short to ground when a specific level of current is achieved.TYPE 2 SPDThe type 2 SPD is the main protection system for all low voltage electrical installations. It protects from over-voltages from switching and indirect lightning strikes. Installed in each electrical switchboard, it prevents the spread of over-voltages in electrical installations and protects the loads.(PowerBreaker SPDs are TYPE 2)TYPE 3 SPDThe Type 3 SPDs have a low voltage discharge capacity and provide local protection for sensitive equipment. They must therefore be installed as a supplement to a TYPE 2 SPD and in the vicinity of sensitive loads.The Institution of Engineering and Technology (IET) Wiring Regulations (BS7671 Section 443) has updated its guidance on SPD devices to include a simplified assessment for when SPDs are required stating:Protection against transient over-voltage shall be provided where the consequence caused by over-voltage:- Results in serious injury, or loss of human life- Results in interruption of public services/or damage to and cultural heritage or,.- Results in interruption of commercial or industrial activity or- Affects a large number of co-located individualsAny commercial, industrial or public buildings that are supplied by overhead lines require surge protection. Likewise, properties located nearby tall structures or tall trees in a lightning prone area should be offered surge protection. Residential properties will depend on use and occupancy levels.For non-residential properties a risk assessment must be undertaken - guidance for which can be found in section 443 of the IET Wiring Regulations.";i:6;s:1625:"Sales Tel: 01279 772772 website: www.greenbrook.co.uk 7Scenario 1SURGE PROTECTION MUST BE PROVIDED Protection against transient over-voltage must be provided where the consequence caused by over-voltage could: - Result in serious injury, or loss of human life - Result in interruption of public services/or damage to and cultural heritage or, - Result in interruption of commercial or industrial activity - Affects a large number of co-located individualsScenario 2SURGE PROTECTION SHOULD BE PROVIDED - Are there overhead lines providing power to the building? - Is the installation in a renowned lightning prone area? - Is there sensitive equipment that requires protection from over-voltages?Scenario 3 - Risk AssessmentA risk assessment should be performed to determine if surge protection is requiredScenario 4 - Single Dwelling unitsSurge protection may be required in single dwelling domestic units if:- The installer establishes that it is what the customer requires- The equipment in the dwelling is of a significant value to require protectionSPD requiredNo Risk Assessment carried out or Calculated Risk Level is less than 1000SPD must be fittedCalculated Risk Level is more than 1000No SPD requiredIt is perceived that the value of equipment warrants surge protectionSPD requiredPlease see Section 443 of the IET 18th Edition Wiring Regulation for further informationCalculated Risk Level (CRL)The Electrical Contractors Association (ECA) have created a calculator to help contractors to undertake the Calculated Risk Level (CRL) of an installation. Please visit www.ECA.co.uk/spd";i:7;s:2449:"8Sales Tel: 01279 772772 Email: sales@greenbrook.co.uk Reference on Site Guide BS 7671, section 3.7.5 shows critical length of connecting conductors for SPDs.To gain maximum protection the connecting conductors must be kept as short as possible to minimize additive voltage drops across the conductors. The total lead length (PE+L) should preferably not exceed 0.5m but in no case exceed 1.0mAs long standing members of BEAMA, the UK electrical industries leading manufacturing association; Greenbrook has always played an active role in promoting product safety and helping to drive the industry forward to ensure the best product standard.PowerBreaker has championed electrical safety and circuit protection in the UK for over 50 years and our range of modules and consumer units have been developed and tested to the highest of standards by an independent test house.SPD Wiring DiagramSPDType 2MAINS SWITCHMCB(32A)LIVE BUSBARReference On Site Guide BS 7671, section 3.7.5Critical lengths of connecting conductors for SPDsTo gain maximum protection the connecting conductors to SPDsmust be kept as short as possible, to mimimize additive voltage drops across the conductors. The total lead length (PE+L) should preferably not exceed 0.5m but in no case exceed 1.0mEARTH BAR1 x NEUTRAL BAR (for part populated boards only)LNPEPENProduct CodeContentsPBSPDType 2 SPD (1 Module) FITTED ONLY IN PBPH22/PBPD16/PBPD18 & PBPDP22 Consumer Units and used in PBSUWKPBSUWKSPD Wiring Kit + Label (1 Module) Kit contains Type 2 SPD (PBSPD), 32A MCB, Connection Wires & LabelPBSMLReplacement Module for (PBSPD) Type 2 SPDDECBA3215468CONPRCD21SCH100002N/AN/ASHEET 1 OF 1SCALE: 1:2DWG NO.TITLE:CAND DESIGN GREENBROOK ELECTRICAL PLC. CONTENTS STRICTLY PRIVATE AND CONFIDENTIAL. TO BE USED ONLY FOR THE PURPOSES NOTIFIED BY GREENBROOK ELECTRICAL PLC. OR ITS LICENCEE. ALL INTELLECTUAL PROPERTY IN AND IN RELATION TO THIS DRAWING AND ITS SUBJECT MATTER ARE RESERVED, AND HEREBY LICENCED TO GREENBROOK ELECTRICAL PLC. ISSCCDDATEDO NOT SCALE THIS DRAWINGDRAWN BYGREENBROOKWEST ROAD, HARLOWESSEX CM20 2BG UK01N/A11/06/21MATERIAL:FINISH:PROJECTION THIRD ANGLE. IF IN DOUBT ASKTOLERANCES(UNLESS STATED OTHERWISE) - 1 DEC PLACE 0.4- 2 DEC PLACE 0.1- ANGULAR 1.0DRAFT CONSIDERATIONS(S) - SMALLEST DIMENSION(L) - LARGEST DIMENSIONGENERAL - 1 PER SIDE 0.5ALL DIMENSIONS IN MILLIMETERS7A3GBSPD Wiring example 2 - Consumer UnitPBPHM** Range";i:8;s:1591:"9Sales Tel: 01279 772772 website: www.greenbrook.co.uk Installation InformationThe PowerBreaker range of circuit protection devices are designed and tested for use with PowerBreaker Consumer Units. These devices MUST be installed by a qualified electrician in accordance with the latest wiring regulations (BS7671).Torque RatingPowerBreaker Consumer Units feature a torque setting sticker in the unit detailing the required torque of the connections. Please ensure you adhere to this for the optimal safe and successful installation of your unit. We would recommend the use of a torque screwdriver. If a connection is not tight enough it can create hotspots and arcing. Likewise, if you over tighten the connection you could crush the conductor causing another hotspot. TestingRegulation 514.12.2 indicates you should be testing your RCDs every six months.TT Earthing SystemsThere is nothing to prevent a metal consumer unit being installed with a TT earthing system but it is important to ensure that an earth fault cannot develop between the meter tails and the metallic enclosure before the RCD. Methods of reducing an earth fault include keeping the meter tails as short as possible, the installation of proprietary clamps and glands to secure the cables and prevent strain on the terminations, minimising the risk of damage.Overload protection of an RCCB or switch in an LV assemblyFor further information on this topic please visit the Beama website :-www.beama.org.uk oruse link https://www.beama.org.uk/static/uploaded/6861a2e1-d8d4-4d81-b5fa710ba60ca4a7.pdf";i:9;s:1385:"10Sales Tel: 01279 772772 Email: sales@greenbrook.co.uk KEY - Consumer Unit Board ModulesBlankingModuleMCBRCCB(RCD)MainSwitchPBPD18 - 18 Module Board Layout6A16A32A32A32A6A6A16A32A40AThe Dual Fully Populated Consumer Unit range is available in 5 Board layouts - 14/16/18/20/22 modulesPBPD14 - 14 Modules:-PBPD14 - 14 Module Board Layout6A16A32A32A6A6A32A40APBPD16 - 16 Modules:-PBPD16 - 16 Module Board Layout6A16A32A32A32A6A6A16A32A40APBPD18 - 18 Modules:-PBPD20 - 20 Modules:-PBPD22 - 22 Modules:-PBPD20 - 20 Module Board Layout6A16A32A32A32A6A6A16A32A40APBPD20 - 22 Module Board Layout6A16A32A32A32A6A6A16A32A40ADual Fully Populated Consumer UnitsContents:- ● 2P Mains Switch 100A ● 2 x Neutral bars ● Detachable Spirit level ● Clear label kit ● 6kA Rated Short Circuit Capacity ● Conforms to BS EN 61439-3● 3 year Guarantee● 8 MCB’s - 1 x 40A, 3 x 32A, 1 x 16A, 3 x 6A● 2 x RCCB 80A, Type A, 30mA ● 10 MCB’s - 1 x 40A, 4 x 32A, 2 x 16A, 3 x 6A● 2 x RCCB 80A, Type A, 30mA● 10MCB’s - 1 x 40A, 4 x 32A, 2 x 16A, 3 x 6A ● 2 x RCCB 80A, Type A, 30mA● 2 x Module blanking plates● 10 MCB’s - 1 x 40A, 4 x 32A, 2 x 16A, 3 x 6A ● 2 x RCCB 100A, Type A, 30mA● 6 x Module blanking plates● 10 MCB’s - 1 x 40A, 4 x 32A, 2 x 16A, 3 x 6A ● 2 x RCCB 100A, Type A, 30mA● 6 x Module blanking plates";i:10;s:424:"11Sales Tel: 01279 772772 website: www.greenbrook.co.uk 14 Way DimensionsFor consumer Unit - PBPD14 3461101062764534130455822524030170357023530Ø32Ø25Ø32Ø254 - Ø2016 - 18 Way DimensionsFor consumer Units - PBPD16 & PBPD184181101063484541330454931524030170357023530Ø32Ø25Ø32Ø256-Ø2020 - 22 Way DimensionsFor consumer Unit - PBPD22 49011010642045485304562.536024030170357023530Ø32Ø25Ø32Ø257-Ø20240";i:11;s:1324:"12Sales Tel: 01279 772772 Email: sales@greenbrook.co.uk The Dual Consumer Unit range are available in 3 Board layouts - 16 modules / 18 modules / 22 modules - all supplied with type 2 SPDPBPDP16 - 16 Modules:-● 8 MCB’s - 1 x 40A, 3 x 32A, 1 x 16A, 3 x 6A● 2 x RCCB 80A, Type A, 30mAPBPDP16 - 16 Module Board Layout6A16A32A32A6A6A32A40A32APBPDP18 - 18 Module Board Layout6A16A32A32A32A6A6A16A32A40A32APBPDP18 - 18 Modules:-● 10 MCB’s - 1 x 40A, 4 x 32A, 2x 16A, 3 x 6A● 2 x RCCB 80A, Type A, 30mAPBPDP22 - 22 Module Board Layout6A16A32A32A32A6A6A16A32A40A32APBPDP22 - 22 Modules:-● 10 MCB’s - 1 x 40A, 4 x 32A, 2 x 16A, 3 x 6A● 2 x RCCB 100A, Type A, 30mA● 4 x Module blanking platesKEY - Consumer Unit Board ModulesBlankingModuleMCBRCCB(RCD)32AMCB for SPDMainSwitchSPDDual Consumer Unit with Type 2 SPDDual Consumer Units Contents:- ● SPD - Type 2 Type 2 SPD is the main protection system for all low voltage electrical installations. Installed in each electrical switchboard, it prevents the spread of over-voltages in the electrical installations and protects the loads ● 6kA Rated Short Circuit Capacity ● 18th Edition Compliant ● SPD protection (32A MCB) ● 2P Mains Switch 100A ● Detachable Spirit level ● Plus label kit ● 3 year Guarantee";i:12;s:314:"13Sales Tel: 01279 772772 website: www.greenbrook.co.uk 20 - 22 Way DimensionsFor consumer Units - PBPDP22 49011010642045485304562.536024030170357023530Ø32Ø25Ø32Ø257-Ø2016 - 18 Way DimensionsFor consumer Units - PBPDP16 & PBPDP184181101063484541330454931524030170357023530Ø32Ø25Ø32Ø256-Ø20";i:13;s:866:"14Sales Tel: 01279 772772 Email: sales@greenbrook.co.uk PBPH22 - 22 Module Board Layout6A16A32A32A32A6A6A16A32A40A32AKEY - Consumer Unit Board ModulesBlankingModuleMCBRCCB(RCD)SpaceforRCBO32AMCB for SPDMainSwitchSPDThe PBPH22 is our Dual High Integrity Unit - 22 modules supplied with type 2 SPDDual High Integrity Consumer Unit with Type 2 SPDPBPH22 Consumer Unit Contents:- ● SPD - Type 2 ● SPD protection (32A MCB) ● 2P Mains Switch 100A ● 2 x RCCB 100A, Type A, 30mA ● 10 MCB’s - 1 x 40A, 4 x 32A, 2 x 16A, 3 x 6A ● 3 x Neutral bars ● 6kA Rated Short Circuit Capacity ● Detachable Spirit level ● 4 x Module blanking plates ● 4 Free ways - 2 for MCB’s & 2 for RCBO’s ● Plus label kit ● 3 year Guarantee 20 - 22 Way DimensionsFor consumer Unit - PBPH22 49011010642045485304562.536024030170357023530Ø32Ø25Ø32Ø257-Ø20";i:14;s:643:"15Sales Tel: 01279 772772 website: www.greenbrook.co.uk The PBSU is supplied with 63A RCCB and 1 x 50A MCB. Shower Consumer Unit Contents:- ● 1 Way for MCB Supplied 1 x 50A ● RCCB 63A, Type A, 30mA ● 3 year Guarantee Consumer Unit Board ModulesMCBRCCB(RCD)50APBSU - 3 Module Board LayoutThe PBGU is supplied with 63A RCCB and 2 MCB’s 1 x 6A & 1 x 16A. Garage Consumer Unit Contents:- ● 2 Way for MCB’s Supplied 1 x 6A & 1 x 16A ● RCCB 63A, Type A, 30mA ● 3 year Guarantee Consumer Unit Board ModulesMCBRCCB(RCD)6A16APBGU - 4 Module Board LayoutShower Consumer UnitGarage Consumer Unit1257518357110.9090.90118";i:15;s:1038:"16Sales Tel: 01279 772772 Email: sales@greenbrook.co.uk The Part Populated Consumer Unit range is available in 8 Board layouts - 8/10/12/14/16/18/20/22 modulesKEY - Consumer Unit Board ModulesSpace for Modules(Free Ways)MainSwitch PBPM14 - 14 Module Board Layout PBPM12 - 12 Module Board Layout PBPM08 - 8 Module Board Layout PBPM10 - 10 Module Board LayoutPBPM14 - 14 Modules:-● 12 Free waysPBPM14 - 12 Modules:-● 10 Free waysPBPM08 - 8 Modules:-● 6 Free waysPBPM10 - 10 Modules:-● 8 Free waysPBPM18 - 18 Module Board LayoutPBPM16 - 16 Module Board LayoutPBPM18 - 18 Modules:-● 16 Free waysPBPM16 - 16 Modules:-● 14 Free waysPBPM20 - 20 Module Board LayoutPBPM20 - 20 Modules:-● 18 Free waysPBPM22 - 22 Module Board LayoutPBPM22 - 22 Modules:-● 20 Free waysConsumer Unit with Main Switch Part Populated Consumer Unit Contents:- ● 2P Mains Switch 100A ● Detachable Spirit level ● 1 x Neutral for use with RCBO Module ● 6kA Rated Short Circuit Capacity ● Plus label kit ● 3 year Guarantee";i:16;s:496:"17Sales Tel: 01279 772772 website: www.greenbrook.co.uk 12 - 14 Way DimensionsFor consumer Units - PBPM12 & PBPM14 3461101062764534130455822524030170357023530Ø32Ø25Ø32Ø254-Ø2016 - 18 Way DimensionsFor consumer Units - PBPM16 & PBPM184181101063484541330454931524030170357023530Ø32Ø25Ø32Ø256-Ø2020 - 22 Way DimensionsFor consumer Units - PBPM20 & PBPM22 49011010642045485304562.536024030170357023530Ø32Ø25Ø32Ø257-Ø208 - 10 Way DimensionsPlease see www.greenbrook.co.uk";i:17;s:395:"18Sales Tel: 01279 772772 Email: sales@greenbrook.co.uk PBCC - Cable Clamp- Pack Qty 1PBB8 - 8 Module Bus Bar- Pack Qty 1PBB12 - 12 Module Bus Bar- Pack Qty 1PBB16 - 16 Module Bus Bar- Pack Qty 1PBB21 - 21 Module Bus Bar- Pack Qty 1PBOMKO - Oval Module Knock Out Guide- Pack Qty 1PBMBB - Blank Module- Pack Qty 1PBLKIT - Consumer Unit Label Kit- Pack Qty 1Consumer Unit Accessories";i:18;s:1348:"19Sales Tel: 01279 772772 website: www.greenbrook.co.uk SPD RangePBSPDPBSMLDescriptionType 2 SPDType 2 SPD - Replacement modulePack Quantity11Barcode50127396486945012739648717Test ClassType IIType IITerminal ConnectionsL - NN - PEL - NN - PERated Working Voltage of Uo (v) 230V~50Hz230V~50HzMax. Discharge Current Imax 8/20μs 40kA40kANominal Discharge Current In 8/20μs 20kA20kAMax. Continuous Operation Voltage Uc 275V255V275V255VVoltage Protection Level Up1.5kV1.5kVShort Circuit Current Rating Isccr500A500AProtection TypeMOVGas Discharge TubeMOVGas Discharge TubeWiring CapacityL/N, PE 6mm²L/N, PE 6mm²Number of Poles22Protection ClassIP20IP20Status IndicatorGreen - NormalRed - FailureGreen - NormalRed - FailureMounting35mm Din RailPush fit cartridgeCasing MaterialThermal Plastic UL94V-0Thermal Plastic UL94V-0DimensionsL81.6 x W18 x D68.5mmL46.3x W18 x D49.15mmGuarantee3 Years3 YearsConforms ToEN 61643-11EN 61643-11+ SPD Kit Part code: PBSUWK - Includes SPD (Part code PBSPD), 32A MCB, connection wires & labels+ Type 2+ Replacement module part code PBSMLThis unit is a single module but has L (Live), N (Neutral) & PE (earth connections), it uses an MOV across the Live & Neutral and a gas discharge tube across Earth & Neutral to dissipate any voltage spikes.Circuit Diagram ";i:19;s:548:"20Sales Tel: 01279 772772 Email: sales@greenbrook.co.uk Mains Isolator SwitchPBIRated Residual Current100APack Quantity6Barcode5012739648526Number of Poles2P (Double Pole)Rated Voltage230/240VACRated Frequency50/60HzTerminal Capacity1 –35mm²Mechanical Endurance10,000 timesElectrical Endurance4,000 timesAmbient Temperature- 25ºC to +55ºCStorage Temperature- 40ºC to +70ºCTorque (Recommended minimum tightening)2.5NmDin Rail MountingYesGuarantee3 YearsConforms ToBS EN 60947+ Rated Short Circuit Capacity 6kA+ 100A+ Double Pole";i:20;s:1039:"21Sales Tel: 01279 772772 website: www.greenbrook.co.uk MCB RangePBMO6BPBM10BPBM16BPBM20BPBM32BPBM40BPBM50BPBM63BRated Residual Current6A10A16A20A32A40A50A63APack Quantity12Barcode50127396485575012739648564501273964857150127396485885012739648595501273964860150127396486185012739648625Number of Poles1P (Single Pole)Rated Voltage230/240VACRated Frequency50/60HzRated Short-Circuit Capacity6kATripping CharacteristicsType BIndex of ProtectionIP20Terminals1 –25mm²Mechanical Endurance10,000 timesElectrical Endurance4,000 timesAmbient Temperature- 25ºC to +55ºCStorage Temperature- 40ºC to +70ºCTorque (Recommended minimum tightening)2.0NmDin Rail MountingYesGuarantee3 YearsConforms ToBS EN 60898+ Rated Short Circuit Capacity 6kA+ Single Pole+ Instantaneous Tripping B CurveType B curve is used for the protection of circuits with equipment that have low surge currents.Type B devices are designed to trip at fault currents of 3 - 5 times rated (In). For example a 10A device will trip at 30-50A instantaneous current.";i:21;s:827:"22Sales Tel: 01279 772772 Email: sales@greenbrook.co.uk RCCB Range+ 30mA Trip Current Type A+ Rated Short Circuit Capacity 6kAPBR80APBR100ARated Residual Current80A100APack QuantityBarcode50127396485335012739648540Number of Poles2P (Double Pole)Rated Voltage230/240VACRated Residual Current30mAType of Residual CurrentType ARated Frequency50/60HzRated Short-Circuit Capacity6kAIndex of ProtectionIP20Terminals1 –35mm²Mechanical Endurance10,000 timesElectrical Endurance4,000 timesAmbient Temperature- 25ºC to +55ºCStorage Temperature- 40ºC to +70ºCTorque (Recommended minimum tightening)2.5NmDin Rail MountingYesGuarantee3 YearsConforms ToBS EN 61009Type A - Tripping is ensured for residual sinusoidal alternating currents and residual pulsating direct currents, whether suddenly applied or slowly rising.";i:22;s:1155:"23Sales Tel: 01279 772772 website: www.greenbrook.co.uk RCBO RangePBO6APBO10APBO16APBO20APBO32APBO40ARated Residual Current6A10A16A20A32A40APack Quantity1Barcode501273964863250127396486495012739648656501273964866350127396486705012739648687Number of Poles1P+NRated Voltage230/240VACRated Residual Current30mAType of Residual CurrentType ARated Frequency50/60HzRated Short-Circuit Capacity6kATripping CharacteristicsType BEnergy Limiting Class3Index of ProtectionIP20Terminals1 –16mm² & 1 –10mm²Mechanical Endurance10,000 timesElectrical Endurance4,000 timesAmbient Temperature- 25ºC to +55ºCStorage Temperature- 40ºC to +70ºCTorque (Recommended minimum tightening)2.0NmDin Rail MountingYesGuarantee3 YearsConforms ToBS EN 61009+ Rated Short Circuit Capacity 6kA+ Single Pole+ Operational Characteristics Type A, 30mA+ Instantaneous Tripping B Curve + Extra length cable for easy installationType A - Provides protection against AC earth fault currents and pulsating DC currents, whether suddenly applied or slowly increasing. Type B curve is used for the protection of circuits with equipment that have low surge currents.";i:23;s:0:"";i:24;s:38:"RCD SOCKET & RCD CONNECTION UNIT RANGE";i:25;s:1640:"26Sales Tel: 01279 772772 Email: sales@greenbrook.co.uk Sales Tel: 01279 772772 website: www.greenbrook.co.uk • Standard BS7288-2016 requires Type A RCDs as well as Type AC RCDs• Type A RCDs detect DC pulsating currents and surge faults that a Type AC RCD may not detect• DC Pulsating currents can be created by faults in modern equipment (e.g. EV car chargers, solar panels, Multi media systems, Smart Speakers, USB Sockets & I-phone chargers)• It suggests that using RCDs to isolate at the point of use avoids more nuisance up stream tripping - leading to power loss of an entire circuit ring and not just on the problem item• The 18th Edition Wiring Regulations suggest the use of socket RCDs in all public areas in addition to those in the Consumer Unit• It is also noted that separate socket RCDs offer better fire protection than solely relying on the circuit board• The new standard demands products that can withstand more rigorous testing (High Voltage & Short Circuit Tests)• PowerBreaker RCDs trip at least 10 milliseconds faster than the BSEN standards require • Safer defence against electrocution• Clear Flag indicators (Red = on, Green = off/safe)• Available in Passive 10mA and Passive 30mA• White & Metal Clad, Switches, Sockets and Spurs• All PowerBreaker products are independently tested by a recognised test houseA RED flag shows that the device is ONwith a Live supply to the appliance.A GREEN flag shows that the device is SAFE with a Live supply switched OFF.18th Edition Wiring Regulations...what does that mean for socket RCDS ?";i:26;s:406:"27Sales Tel: 01279 772772 website: www.greenbrook.co.uk PowerBreaker RCDs are slim & stylish - suitable for all installationsRCD SocketsPage NoUnswitched Sockets28Panel Mounting Sockets29Switched Sockets30RCD Fused Connection UnitsPage NoWhite & Metal Clad Fused Connection Units3110mA RangePage NoSwitched Socket32White & Metal Clad Fused Connection Units33In-Line RCDsPage NoIn-Line RCDs34";i:27;s:905:"28Sales Tel: 01279 772772 Email: sales@greenbrook.co.uk Sales Tel: 01279 772772 website: www.greenbrook.co.uk TECHNICAL INFORMATIONVoltage230V AC ~ 50HzMax Operating current13A (13A Inductive)Typical Trip SpeedLess than 20mS (typical)RCD contact breakDouble PoleDegree of ProtectionIP40Rated Short-circuit breaking & making Capacity250ARated conditional Short-circuit current1500A Power factor Range .93 to .98Independently tested toBS 7288:2016, BS 1363-2:2016BS1363-4:2016 (SPUR) Mechanically latched (does not need resetting after a power loss) Red & Green dual flag system to show power on/off High intensity LED power on indicatorRCD Sockets - 30mAPassive - Type A RCDsPart NoDescriptionH22-WPRCD Twin SocketSlim profileScratch resistant urea front plateFits standard 35mm back boxH22-MPRCD Twin SocketComplete with metal backboxH22-WPH22-MP30mASocket---Passive-";i:28;s:917:"29Sales Tel: 01279 772772 website: www.greenbrook.co.uk Part NoDescriptionK21S-WPPanel Mounting RCD SingleSwitched SocketMoulded front plateMax Plate Thickness 2mmK22S-WPPanel Mounting RCD TwinSwitched SocketMoulded front plateTwin earth terminalsMax Plate Thickness 2mmRCD Sockets - Switched Panel Mounting 30mAPassive - Type A RCDsK21S-WPK22S-WPTECHNICAL INFORMATIONVoltage230V AC ~ 50HzMax Operating current13A (13A Inductive)Typical Trip SpeedLess than 20mS (typical)RCD contact breakDouble PoleDegree of ProtectionIP40Rated Short-circuit breaking & making Capacity250ARated conditional Short-circuit current1500A Power factor Range .93 to .98Independently tested toBS 7288:2016, BS 1363-2:2016BS1363-4:2016 (SPUR) Mechanically latched (does not need resetting after a power loss) Red & Green dual flag system to show power on/off High intensity LED power on indicator30mASocket---Passive-";i:29;s:1061:"30Sales Tel: 01279 772772 Email: sales@greenbrook.co.uk Sales Tel: 01279 772772 website: www.greenbrook.co.uk RCD Sockets - Switched 30mAPassive - Type A RCDs Mechanically latched (does not need resetting after a power loss) Red & Green dual flag system to show power on/offPart NoDescriptionK21-WPRCD Single Switched SocketSlim profileMoulded front plateFits standard 35mm back boxK22-WPRCD Twin Switched Socketslim profileMoulded front plateFits standard 35mm back boxK21-MPRCD Single Switched SocketComplete with metal backboxK22-MPRCD Twin Switched SocketComplete with metal backboxTECHNICAL INFORMATIONVoltage230V AC ~ 50HzMax Operating current13A (13A Inductive)Typical Trip SpeedLess than 20mS (typical)RCD contact breakDouble PoleDegree of ProtectionIP40Rated Short-circuit breaking & making Capacity250ARated conditional Short-circuit current1500A Power factor Range .93 to .98Independently tested toBS 7288:2016, BS 1363-2:2016BS1363-4:2016 (SPUR)K21-WPK22-WPK22-MPK21-MPK21-WPK21-MPK22-WPK22-MP30mASocket---Passive-";i:30;s:917:"31Sales Tel: 01279 772772 website: www.greenbrook.co.uk Part NoDescriptionH92-WPRCD Fused Connection UnitScratch resistant urea front plateFits 35mm standard back boxH92-MPRCD Fused Connection UnitComplete with metal back boxTECHNICAL INFORMATIONVoltage230V AC ~ 50HzMax Operating current13A (13A Inductive)Typical Trip SpeedLess than 20mS (typical)RCD contact breakDouble PoleDegree of ProtectionIP40Rated Short-circuit breaking & making Capacity250ARated conditional Short-circuit current1500A Power factor Range .93 to .98Independently tested toBS 7288:2016, BS 1363-2:2016BS1363-4:2016 (SPUR) Mechanically latched (does not need resetting after a power loss) Red & Green dual flag system to show power on/off Fused for all fixed electrical appliances Cuts the power for added protection against electrocutionRCD Fused Connection Units - 30mAPassive - Type A RCDsH92-WPH92-MPH92-WPH92-MP";i:31;s:1199:"32Sales Tel: 01279 772772 Email: sales@greenbrook.co.uk RCD Sockets - Switched 10mAPassive - Type A RCDs Mechanically latched (does not need resetting after a power loss) 10mA sensitivity providing greater protection Red & Green dual flag system to show power on/off Fused for all fixed electrical appliances Cuts the power for added protection against electrocutionPart NoDescriptionK21-WP10RCD Single Switched SocketSlim profileMoulded front plateFits standard 35mm back boxK22-WP10RCD Twin Switched SocketSlim profileMoulded front plateFits standard 35mm back boxK21-MP10RCD Single Switched SocketComplete with metal backboxK22-MP10RCD Twin Switched SocketComplete with metal backboxTECHNICAL INFORMATIONVoltage230V AC ~ 50HzMax Operating current13A (13A Inductive)Typical Trip SpeedLess than 20mS (typical)RCD contact breakDouble PoleDegree of ProtectionIP40Rated Short-circuit breaking & making Capacity250ARated conditional Short-circuit current1500A Power factor Range .93 to .98Independently tested toBS 7288:2016, BS 1363-2:2016BS1363-4:2016 (SPUR)K21-WP10K22-WP10K21-WP10K22-WP10K21-MP10K22-MP10K21-MP10K22-MP10‘ SUPER SENSITIVE 10MA ‘10mASocket---Passive-";i:32;s:1377:"33Sales Tel: 01279 772772 website: www.greenbrook.co.uk TECHNICAL INFORMATIONVoltage230V AC ~ 50HzMax Operating current13A (13A Inductive)Typical Trip SpeedLess than 20mS (typical)RCD contact breakDouble PoleDegree of ProtectionIP40Rated Short-circuit breaking & making Capacity250ARated conditional Short-circuit current1500A Power factor Range .93 to .98Independently tested toBS 7288:2016, BS 1363-2:2016BS1363-4:2016 (SPUR)Part NoDescriptionH92-WP10RCD Fused Connection UnitScratch resistant urea front plateFits 35mm standard back boxH92-MP10RCD Fused Connection UnitComplete with metal back boxTECHNICAL INFORMATIONVoltage230V AC ~ 50HzMax Operating current13A (13A Inductive)Typical Trip SpeedLess than 20mS (typical)RCD contact breakDouble PoleDegree of ProtectionIP40Rated Short-circuit breaking & making Capacity250ARated conditional Short-circuit current1500A Power factor Range .93 to .98Independently tested toBS 7288:2016, BS 1363-2:2016BS1363-4:2016 (SPUR) Mechanically latched (does not need resetting after a power loss) 10mA sensitivity providing greater protection Red & Green dual flag system to show power on/off Fused for all fixed electrical appliances Cuts the power for added protection against electrocutionRCD Fused Connection Units - 10mAPassive - Type A RCDsH92-WP10H92-MP10H92-WP10H92-MP10‘ SUPER SENSITIVE 10MA ‘";i:33;s:779:"34Sales Tel: 01279 772772 Email: sales@greenbrook.co.uk Suitable for BS/European power supply systems Robust construction Mechanical flag to indicate contact position Double Pole breaking Separate test and reset buttonRCD In-Line - 30mAActiveTECHNICAL INFORMATIONRated Trip Current30mATypical Trip Speed<40mSRCD contact breakDouble PoleLatchingElectrical - Needs resetting after power loss (Active)Conforms toIEC 61540Part NoDescriptionJ62-TIn-Line RCDHeavy Duty, IP65Re-wirable terminals230V AC 50/60HzMax operating current 16AJ62-YIn-Line RCDHeavy Duty, IP65Re-wirable terminals110V AV 50/60HzMax operating current 16AJ63-XIn-Line RCD with IEC Lead Indoor use only, IP20Fully portable230V AC 50HzMax operating current 10AJ62-TJ62-YJ63-XJ6247.0050.80161.50";i:34;s:0:"";i:35;s:106:"Issue No: 706310Sales Tel: 01279 772772 Email: sales@greenbrook.co.uk Website: www.greenbrook.co.uk";}
Is PDF to HTML Checked:
Update date:
02/08/2021
Number of thumbnail page:
Pages counter:
Page to display after flipbook opening:
2
Year:
2021
Target group:
Show body:
PDF Thumbnail:
View the full article
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
