DONT STAY LURKING AS A GUEST,
CLICK HERE TO JOIN.
relay 12v-230v
ktguk
anyone know where u can get a relay that switches 230v ac from 12v dc, want to use a output from alarm to switch the relay to switch the flood lights on to perm. so the sounder, strobe and floods willl come on when triggered
cheers
Link to comment
you will find many relays are capable of switching 230V, but the small PCB type may only be 1 or 2A
Link to comment
think best to hav to relay switch a contactor
possibly. although you can get some relays with larger terminals that a spade connector could fit onto. or you can get 'plug in' type, with 8 (or 11) pins which plug into a base with proper terminals (and fixing points)
Link to comment
RS or Farnell . RS don't list their relays very clearly lately . 12v relay switching a contactor may best, as said.
Link to comment
awesome SL
is the data sheet wrong tho?
i.e 1 rating for resistive and there should be a lower rating for inductive
Applaud Smiley:D
flippin ek Lostit!!!!!:o
Data sheets......?:|
you been off reading extra links.....
so long as the coil & contact rating is ok I'm happy..............
PLUS
I have had too many Guiness DrinkGuiness DrinkGuiness DrinkGuiness Drink
now to even find a data sheet!!!
:P:p:pBlushing
:coat
Link to comment
i always feel safer switching 12v over 240v at any distance by using a relay, it costs more but is safer in the long run (and sometimes cheaper)
bob
Link to comment
A relay is a smaller version of a contactor.
Link to comment
Always best to put the relay in a adaptor box marked 240 away from the alarm panel not inside the alarm panel.
fuse the 12 volt feed from the alarm panel.
As stated by others availible at all good wholesalers.Maplins are expensive compared to Farnell or CPC.
Price you pay for the goods when you need them.
Link to comment
and CPC/farnell have a min order before you get free P&P
Link to comment
As does Maplin..................
Link to comment
Indeed..
Maplin do have quite a few stores around the country so you can often drop in to pick the odd one-off bits up without too much hassle!..
I got 2x Maplin stores within 15mins drive from home, (opposite directions!)
whereas CPC/Farnell, RS got to be at least 1/2hour minimum travelling!:(
Link to comment
but there are a lot more maplin's about than CPC's!
Link to comment
not where I live :P
:D
Link to comment
TLC keep `em in stock - 8 pin octal bases (or 11 pin if you want changeover contacts). Many coil voltages available, and the contacts are 10A rated (resistive).
i.e.: http://www.tlc-direct.co.uk/Products/SR504.html
(about 6 quid.)
HTH
KME
Link to comment
Archived
  • Create New...
