DONT STAY LURKING AS A GUEST,
CLICK HERE TO JOIN.
  • 0
Fuseboard Size
wozz
Question
Hello lads
just wondering if anyone has noticed the shortest (as in height) fuseboard they have installed(5&5 dual split)?
Im restricted for space on a CU change, the shortest i can find is a MK at 225mm, i need it 210mm.
There is other ways but keeping it where it is would look neatest.
cheers
Link to comment
5 answers to this question
Wozz what about just making up an RCBO board?? They are generally smaller than split boards.
AndyGuiness Drink
Link to comment
its the height of the board im struggling with, im ok with the width, was just wondering if there are any brands out there that are a tiny bit shorter than MK, hager and wylex are both taller:_|
Link to comment
Not really wozz as board designers should be taking into account bend radii etc at the design stage. This in turn means that there will generally be a minimum height for a CU carcass.
AndyGuiness Drink
Link to comment
Archived
  • Create New...
