DONT STAY LURKING AS A GUEST,
CLICK HERE TO JOIN.
  • 0
Pir....how long?
meady
Question
Got a fella that wants me to carry out a pir on 4 of his rental flats. They are all 2 beds with no more than 5 circuits. How long roughly would you allow for a full pir? I have got to work it around a job at the moment but could find it hard to find the time
Link to comment
10 answers to this question
allow at least half a day
remember take your time, get it right, and price the remedials as you go. nothing worse than putting in a report with out the remedials priced correctly.
Link to comment
depends how much testing you do... maybe 2 1/2 hours each
Link to comment
Are you looking to pass this job on to someone else?
Link to comment
As a rough guide I try and work to about 40mins per circuit
i.e. 5 x 40 = 200mins / 60 mins per hour = 3.33 (3 and a half hours)
Not all the jobs are the same but its useful as a rough guide.
Just remember that if you haven't taken the fuseboard covers off any of the boards there could be some doubled up or even tripled up MCB / fuses, thus making your straight forward 5 way boards into 6,7,8,9,10 ways etc!
Hope this helps.
Warren
Link to comment
I'd go with half a day for each one, myself. Assume they are local.?
Link to comment
I have done hundreds possibly thousands of PIR's over the last 11 years whilst being employed by various contracting companies. One company tried to make me do each one in 2 hours but I found that to be far too little time. My present employer allows approx 4 hours per installation which I think is a very fair time which I find gives me enough time to do all the testing properly (including the three ring continuity tests) and fill in the NICEIC form neatly having identified every fault/ defect.
Link to comment
I'd allow 1/2 day each as well, could probably do one in three hours, but the thought of 3 PIRs in one day makes me suicidal, so for health & safety reasons, it's two per day!
Link to comment
From the (experienced) comments and my boys experience, 2.5-4 hours is the top and bottom for the size of the installation mentioned here.
Don & His Boys
Link to comment
As said...
typically 1/2 day...
If a customer asks over the phone for a typical domestic semi, I always quote.. between 1/2 to a full day..
depending upon what is found and any level of greater investigation that may be neeeded....
As a rule of thumb...
Allow 1/2 hour per circuit plus 1/2 hour for general investigations of CU or any 'hidden' accessories!
So your flats would be at least 3 hours MINIMUM IMHO
DON'T forget you have to write up your report and there may be other observations that NOT life threatening do need drawing to the customers attention!
Link to comment
Archived
  • Create New...
