DONT STAY LURKING AS A GUEST,
CLICK HERE TO JOIN.
Countdown To Christmas!
  • 0
may have F**ked up!
danny7299
Question
I have been getting my job's together to register with NICEIC Domestic. And there are something is wanted to check...
The Major Job is a kitchen Extension, with bathroom and changing room above it.
Due to the way the house was laid out, I decided to run a sub feed to the Extension and run all new cables to the new Dis board. In hindsight I should have done this in SWA but I clipped 16mm T&E to the ceiling Joist before the ceiling went up. But I didn
Link to comment
SPECIAL LOCATION
I undestood it that no 240V switch gear should be in the bathroom in or out of zones, apart from pull switch because of suitability for the environment. However, talk nicely to inspector bloke and go 'oh silly me look what I did, v sorry won't do it again, promise to fix soonish' and he'll probably let you off anyway.
another old MYTH I am afraid!
BS7671 pages 165 to 169 covers regulations for rooms containing a bath or shower.
e.g.
701.512.2 External influences.
zone 0 at least IPX7.
zone 1 and 2 IPX4.
OUTSIDE OF ZONES... no major problems UNLESS exposed to water jets
e.g. for washing down / cleaning at least IPX5.
i.e.
3pole Isolators,
fused spurs
light switches
CAN be installed INSIDE the bathroom..
provided not in zones 0,1 or 2!
even a socket outlet can be fitted if its 3m horizontally from edge of zone 1
STEAM and moisture are not much worse than in a kitchen during cooking where sockets & switches can be within 300mm of ovens sinks etc.!!!
Link to comment
SPECIAL LOCATION
Only if suitable for enviroment so I would not put a normal light switch in any bathroom. Could use mk masterseal though
Normal light switch is suitable provided you are not hosing your walls down.
and its outside of zones.;)
Link to comment
Bit like I said then :P
Link to comment
SPECIAL LOCATION
Binky - thought you could now have a normal light switch or even a socket outlet if outside of zone?
Correct Patch!:DApplaud SmileyGuiness Drink
you could have a normal switch outside of zones in old regs as well!
ye old zone 3 requirements referenced to IPX5 IF communal baths & showers where wall may be hosed down for cleaning.
reg 60106-01, Bottom of page 135 old brown book!
your average domestic bathroom is an environment with minimal adverse external influences......
other wise the wallpaper would keep falling off the walls
and the towels on the towel rail would be dripping wet
and you would never have found a bathroom with carpet
cuz it would have been sodden!
I think some contractors avoid putting anything in a bathroom for fear of sticking it in the wrong place.:(
Link to comment
SPECIAL LOCATION
calm down boy...
I was answering your bit as well!
Blushing:x:^O:p
Link to comment
The Godfather
I'm not sure about admins view, but Danny no need to use such abbreviated words on the title of your thread.
'Messed up' would of been fine, in the Don's book.
The Godfather
Link to comment
Been fitting 3 pole switchs for a while now so cant quite remember but if the bathroom has a window do you need a switch if not could you blank plate it for the inspection.
Link to comment
Good idea to fit a switch for maintanance and if it goes wrong customer can isolate without calling sparks.
Batty
Link to comment
Link to comment
Binky anything like that I use a drylining box in the ceiling, I am finniky. It wouldnt take much to swap a 3 pole switch over to a 3 pole pull cord switch.
AndyGuiness Drink
Link to comment
Fair enough
Link to comment
Batty
and the instructions will say you have to have one along with a 3A fuse usually.
If it was for my assessment i would put a lockable switched fused spur in the feed for the bathroom and remove the local isolator, i cant see how you can wrong doing this.
Is the fan of a appropriate IP rating for its position?
Link to comment
Only problem with this if you switch spur of lighting will be off to. I think fan switch should be enough that way with fan switch off it is isolated and it also gives people option of having it off or not at night.
Batty
Link to comment
accepted i would not wire it like this in my bathroom but if its for my assessment and the customer didnt state they want a accessible kill switch for the fan i woudnt install one.
i cant see a spur controlling the fan and lighting a non compliance? but i could be proved wrong.
Link to comment
I have always only used fan isolation switches and no spurs and never have had problems on my assessments.
Batty
Plenty of sparks put no isolators in at all.
Link to comment
My understanding:
1. 16mm2 T&E will need RCD protection if installed less than 50mm in a WALL........
2. Isolator OK if outside zones, otherwise doesn't comply
Link to comment
I`d concur with this mate. why would you have used SWA?
Link to comment
Link to comment
Link to comment
simply because that what me old boss made me do in that past...
so the real isue is the isolator, the customer hasn;t got the plumber to 2nd fix yet and by the sounds of it when the NIC come round it still wont be 2nd fixed. any other options if it is in zone 2?
dont think you can get a pull chord can you? he he
Link to comment
Archived
  • Create New...
