DONT STAY LURKING AS A GUEST,
CLICK HERE TO JOIN.
  • 0
Job for Assessment
Couleddie
Question
Fitting some downlighters in a bedroom in my brother's house. Going to use this as second job for assessment once i've got around to deciding who to go with.
Needless to say i'll be doing a sound job but in terms of the assessment will there be anything in particular in this job that they'll look for that I need to really concentrate on?
Link to comment
11 answers to this question
That may not be a "big" enough job as its not really a modification of a circuit unless you are running a 2nd switch in (for switching different groups of downlighters in the room) or some such thing.
Link to comment
Good point. Hadn't thought of that. The first job is a CU change (my own) which has already been done so I really need to be looking for an extra socket type of job then?
Link to comment
i went with Elecsa and they were happy with 1 job
Link to comment
Elecsa said as many as possible to me but when they showed up they only looked at my major job as we ran out of time. As long as the assessor doesn't see anything he doesn't like on that main job, he most likely won't bother with the others.
Link to comment
I had that debate at the beginning of the year and after contacting them both and getting opinions, I opted for ELECSA as they seemed much more in tune with the sparks and not just out to take your money. That's my view but others may have different views.
Also I tend to rebel against the larger corps (I don't use Microsoft unless I really have to), and far too many ignorant people still link only NIC people can do DI's.
Link to comment
just looked on the new post they are debating the same thing.
i think i will shop around more
the only advantage with nic i have seen so far is that they are well known,
Link to comment
But ELECSA have a nice lady called, erm, well they have a nice lady that will call people you come across that think NIC is the only way. Most local Govt are not so narrow minded any more.
Link to comment
I second this!
there are advantages on both sides, but with nic the certs are more expensive as is everything else, they will sell you anything thay can along with your membership. the elecsa assesser i had said dont bye pads print them free from there site and photocopy them
Link to comment
You don't have to use the NIC certs either.. all you have to do is give them a serial number and keep a log!
Link to comment
Archived
  • Create New...
