DONT STAY LURKING AS A GUEST,
CLICK HERE TO JOIN.
  • 0
invertor fault
moose man
Question
hi all
There is a pir being done at my work at moment
by a company i would just like to ask is it possible to damage a invertor
on a earth loop test as
because before the test was done it work fine
the make is control tech commander se but code HF73 as come on the screen hard drive fault
moose man
Link to comment
11 answers to this question
The error code says that it is a communication problem between the two microproccesors.
Try a reset if not check the connections on the RS 485 link between the two.
Link to comment
To cover O/P, a loop does wouldn`t cause this problem. Only, as said, an insulation test. Agree that it sounds like a board fault on startup manifesting.
HTH
KME
Link to comment
i powered down for 10 mins and yes it came back on for about 1 hour then shut down
and it will not come back on now but still as the same code were is the RS 485 link
located thanks for your advise as invertors are new to me i will keep it on board for the future
what is o/p sort for
Link to comment
Opening post :D
Link to comment
I have never worked on the particular invertor you have, but the error code corresponds with it being unable to communicate internally between the two microproccessors, on some these are seperate boards connected via ribbon connectors internally and a possible cause of this fault. Maybe that one of these is loose, however it could be that they are on the same circuit board, in which case it may require a new board to cure the fault.
Hope that helps some.
Link to comment
hi Russell R
I gave control tech a ring today and they said it would be cheaper to buy a new invertor
then to replace the two boards the commander se s been replaced with a commander sk
which will do the same job
Link to comment
Any high voltage put through any electrical componant could and will damage the circuits.
Most sensitive equipment would not have a mains 500v dc insulation test, and the earth continuity test would be fruitless as most if not all pcb boards are not earthed for obvious reasons.Any such equipment must be isolated from the supply before any tests are carried out.
Without knowing the circumstances of the tests I could not really comment on your problem, other than to say I would not have done any high testing on an invertor.
Link to comment
thanks for the reply as far as i am aware they said they did not do a insulation test
but a earth loop was done the isolater was in open pos but the earth was still linked
with the invertor it was done on a hi loop between phase and earth could the fault current go down the earth to the invertor
Link to comment
Archived
  • Create New...
