DONT STAY LURKING AS A GUEST,
CLICK HERE TO JOIN.
  • 0
Long Test Leads
Couleddie
Question
Been looking on RS Components for stuff I need to make myself a long test lead but having trouble finding the right bits. Can someone help me out on this with some links? I know a few of you have made your own.
Link to comment
11 answers to this question
Yeah - 1 X 50m roll of 1.0mm stranded - any colour. Job done.
Cheap & cheerful.
KME
Link to comment
Or get a cheap extension reel with a plug & fly leads.
Link to comment
i got a socket and see kit that fits onto an extention cable cost about 20 quid
Link to comment
If you want to make a wander lead then you need...
An extension lead (cassette type) - unreel the cable and throw away (or use for a job).
A 4mm banana socket
50m 1.5mm tri-rated cable
A heavy duty croc clip..
OR
A 50m extension lead
A 13a plug top
1m of flex core
Wire the flex to the plug (earth) and plug into extension reel --- you now have a wander lead (earth pin to flex)
Link to comment
I just carry a roll of 1.0mm stranded with bare ends. Screw into terminal at CU, and croc clip to the bare end at the far end - What`s the issue?
And mine is cheaper & easier to store / move / make than any of the other options.
Link to comment
That's wrong on 3 counts.
Cheaper, yes (but don't expect to be able to use that for conduit anymore).
Easier to store: no, it winds nicely.
Easier to move: no, it has a nice carry handle.
Easier to make: no, its already made up.
It also lays alot better when moving so less likely to be a trip hazard too.
Ian.
Link to comment
I have the made up roll and find it easier than drum of 1.0m.
But going off on a bit of a tangent I mostly use it for gas & water bond continuity but occasionally will do r2 checks, on my NIC assesment last year inspector said I shouldnt do that as I aint checked polarity. My
Link to comment
I often do R2 on lighting ccts. If you back it up with a non-contact voltage tester, I don`t see a problem. Zs is just belt & braces, as far as polarity is concerned. My opinion anyway.
KME
Link to comment
Archived
  • Create New...
