DONT STAY LURKING AS A GUEST,
CLICK HERE TO JOIN.
help pls!!
eren
would anyone help pls! i need to know the dscription for inspection process that would be carried out on an industrial installation prior to commissioning, in terms of STEEL CONDUIT and STEEL TRUNKING.
Link to comment
Are they asking for "earth continuity tests" of the steel conduit/trunking before energising?
Link to comment
Are you saying the steel conduit and trunking are used as the earth CCPs ?
Link to comment
Correction to Oracle: High current continuity test is now NOT recommended, as a hidden joint at high resistance could cause arcing, with the subsequent risk of fire.
Link to comment
Archived
  • Create New...
