help pls!!
eren
Sep 11, 2009
would anyone help pls! i need to know the dscription for inspection process that would be carried out on an industrial installation prior to commissioning, in terms of STEEL CONDUIT and STEEL TRUNKING.
Do you have any more info?
The inspection process is outlined in both GN3 and BS7671 if that helps?
Are they asking for "earth continuity tests" of the steel conduit/trunking before energising?
Hi there,
If CPC I would assume a R1+R2, Zs
Either way a high current continuity test.
O.
