DONT STAY LURKING AS A GUEST,
CLICK HERE TO JOIN.
Countdown To Christmas!
Voltimum - Crabtree Starbreaker Miniature SPD Overvoltage Protection Device
Social Integrator
Teaser text:
MINIATURE SPD FOR SURGE PROTECTION IN DOMESTIC HOUSEHOLD PREMISES
PDF to HTML:
a:4:{i:0;s:57:"Starbreaker Miniature SPD Overvoltage Protection Device";i:1;s:1137:"MINIATURE SPD FOR SURGE PROTECTION IN DOMESTIC HOUSEHOLD PREMISES SINGLE MODULE SPD At just 18mm wide this miniature SPD leaves more ways for household circuits and allows the most compact consumer unit to be used. FULLY RATED 100A No need for an additional back up device in the consumer unit. SIMPLE TO INSTALL Plugs directly onto the busbar (just like a Starbreaker MCB) Instantly connecting it to the busbar. LESS WIRING Fewer cable links to connect than alternative products, which speeds up installation (supplied with cables). TYPE 2 SURGE PROTECTION With status indicator and volt free contacts for remote monitoring and/or signalling. SECURE CARTRIDGE ASSEMBLY Once Installed, cartridges are securely locked into place and cannot be removed for replacement without use of a tool. CERTIFIED AS FULLY COMPLIANT Crabtree single module SPDs are designed, manufactured & tested to IEC EN61643-11 and certified as compliant. RETROFIT COMPATIBLE Fits all Starbreaker consumer units*. Supplied with a retrofit circuit icons label pack. * Not suitable for Dual RCD configurations 2Starbreaker Main Switch Consumer Unit";i:2;s:1765:"3SBT2SPD3W/1CRT2SPD/PREPLACEMENT PLUG-IN CARTRIDGE CAT REF DESCRIPTION CRT2SPD/P Replacement Plug-in Cartridge for SBT2SPD3W/1 • Combined Metal Oxide Varistor (L1 & N) and Gas Discharge Tube (N & E) Surge Protection DevicesSURGE PROTECTION DEVICE CAT REF DESCRIPTION SBT2SPD3W/1 Miniature Type 2 SPD • Suitable for all Single Phase 3 Wire Systems TN-C-S, TN-S and TT • Clear Indication of device status • Fitted with remote signalling contact • Starbreaker device with plug-in busbar connection • Suitable for use in Main Switch, Split Load & Hi-Integrity consumer unit configurations • Not suitable for Dual RCD configurations Alternative SPD products are available for Dual RCD consumer unit installations. Please contact Crabtree technical for further assistance.TECHNICAL DATA Product Standard IEC EN 61643-11 Nominal discharge surge current (8/20) μs 20kA Short-circuit breaking capacity (Isccr) 25kA Max. continuous voltage AC 275V Max. discharge surge current (8/20) μs 40kA Voltage protection level 1.3 kV Voltage protection level L-N 1.3 kV Voltage protection level N-PE 1.3 kV Degree of protection IP20 Dimensions Height 85mm x Width 18mm x Depth 70mm";i:3;s:1006:"Although every effort has been made to ensure accuracy in the compilation of the technical detail within this publication, specifications and performance data are constantly changing. Users should always consult the installations instructions, IET wiring regulations and all other relevant documents, and not solely rely on information in this catalogue. Publication No. B2609 09/2021 ELECTRIUM SALES LIMITED A SIEMENS COMPANY Commercial Centre, Lakeside Plaza, Walkmill Lane, Bridgtown, Cannock WS11 0XE. eMail: info@electrium.co.uk www.electrium.co.uk UK SALES Telephone: 01543 455010 Facsimile: 01543 455011 eMail: crabtree.sales@electrium.co.uk TECHNICAL Telephone: 01543 438310 Facsimile: 01543 438311 eMail: crabtree.technical@electrium.co.uk EXPORT SALES Telephone: +44 1543 455049 Facsimile: +44 1543 455048 eMail: export@electrium.co.uk DUBAI OFFICE Telephone: +971 4 3660684 Facsimile: +971 4 3660676 eMail: export@electrium.co.uk@ElectriumNews or download the APP";}
Is PDF to HTML Checked:
Brand:
Update date:
18/10/2021
Number of thumbnail page:
Pages counter:
Page to display after flipbook opening:
2
Year:
2021
Target group:
Show body:
PDF Thumbnail:
/sites/www.voltimum.co.uk/files/pdflibrary/images/crab_tree.png
View the full article
Link to comment
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
Guest
Reply to this topic...
×   Pasted as rich text.   Restore formatting
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
  • Create New...
