Honeywell Accenta G4 LCD Keypad - replacement
richchap
Oct 19, 2021
Hi guys,
First post on here, so please be gentle.
I have a Honeywell G4 alarm at home with an Accenta LCD panel (8EP417A-EU). The panel is on it's way out I think, the keys are beginning to fail and it seems we need to press them harder every other day.
The alarm has been installed for 10+ years and I've had no faults with it. The rest of the system is sound.
I feel I need to replace the keypad, however this panel is not discontinued and I cannot find one anywhere.
Is it possible to install a different make of panel or is this going to be a case of a new alarm system? If the panel can be changed with another make, what do you guys recommend as a compatible option?
Thanks in advance
You can't use BRAND A keypad on BRAND B panel, why not just buy a new keypad? This place  have them.
Hi guys,
Thanks in advance
LCD keypad is still available..
https://www.securitywarehouse.co.uk/catalog/intruder-alarm-c-36/security-control-panels-c-36_102/control-panels-all-c-36_102_41/ade-honeywell-lcd-keypad-for-optima-accenta-control-panels-p-865.html?zenid=sjnvs3ure4sa7r0ip1fmkapg01
Not sure if Richard 9th link includes VAT..
or where they are physically located as a business..
But I do know I have used Security Warehouse myself numerous times in the past..
(They are only 25mins drive from my home!!)
And they are a reliable supplier..
Either way that's 2 supplier options and I am confident there will be more options if you go a Googling!
Guinness
