DONT STAY LURKING AS A GUEST,
CLICK HERE TO JOIN.
Countdown To Christmas!
Weird.... fault
1 common dist board
10 circuits of led lighting..  separate rcbos  approx 40 led lamps total
Leds Suddenly started to dip for a split second every 50 seconds...
Checked all connections tight...
Checked supply to dist board
No joy
Anyone any suggestions?
Link to comment
Sharpend
Any large loads? Either in your building or possibly near by?
Link to comment
Big building..... but nothing large or new comes to mind....
Total building load approx 300A per phase....
Prob 100 rooms in building... so almost impossible to police loads
Link to comment
Have you put a clamp meter (tong tester) onto the incoming phases to see if a high current demand coincides with leds dipping. Any other testing done Hz?
The electricity board doesn’t happen to have a temp generator on the feed to that area due to say a cable fault does it?
Anybody doing any welding in the building?
Do the LEDs come back to a common controller like a DALI?
Could one faulty LED fitting in the circuit say briefly shorting, cause the rest to dip? Dunno.
Just thinking of various things of the top of my head.
Edited by roys
Link to comment
Sharpend
Office?
Link to comment
Thanks for the replies
The building/site is a TV studios
The phase loading constantly changes with use.
You could say the whole site is probably 100 1ph rooms
60% with predictable loads, the remaining is unpredictable...
So phase balancing is erratic.
During the last 3-4 years we have replaced all the fluorescent office lighting with led panels but they all seem ok.  (Probably better drivers)
Currently the issue is just one film set.
No common controller.  Individual circuits
Tried each circuit from the board separately each still dips.
So appears to be a supply issue....
Going to try today
Test supply cable
Installing better quality LEDs
Check phase imbalance at site incoming supply (although this whole set is 1ph)
Another crude solution might be to restore the original tungsten lamps to the set
(They where replaced with LEDs 2 years ago)
Link to comment
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
Guest
Reply to this topic...
×   Pasted as rich text.   Restore formatting
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
  • Create New...
