DONT STAY LURKING AS A GUEST,
CLICK HERE TO JOIN.
  • 0
Fitting A single Phase time clock to a 3 phase contactor
Barker
Question
hi,
I need to fit a a time switch to a 3 phase fan unit on an agriculteral grain dryer, as some of you have suggested the best way of going about this would be to fit a single phase time clock controlling a three phase contactor.
As everything is in place and most of it has been since before the war (and i don't mean the Gulf war or the Falklands one) i was hoping to split the cable and feed it into a box with a din rail mounted contactor, what I was after was advise on the best pay to power the timer, can I spur from one of the phases before the box or will I need to fun it all the way back to the main boards?
Thanks in advance.
Link to comment
2 answers to this question
Come off one of the phases, fuse down through a Slydlock fuse or simlar . This will power the timeswitch clock , loop to n/o contacts then to coil. I assume you have a neutral there ??
Link to comment
or fit a 1 or 2a mcb to the din rail fed by one of the phases this now becomes your control circuit protection Guiness Drink
provided there is a neutral as not generally needed for motor control/power
Link to comment
Archived
  • Create New...
