DONT STAY LURKING AS A GUEST,
CLICK HERE TO JOIN.
Countdown To Christmas!
  • 0
ir on ring main
tom1
Question
insulation test on ring came up with 59M ohms
looked at his last nic eice cert dated 2 year back he got 200M ohm
its the old stranded cable i advised he should replace it befor he decorates.
thats a big deteriation i wonder if the last guy even did the test and why he left in the stranded cable
Link to comment
7 answers to this question
the cu was a bit strange as well,
rcd, 2 16a radals 1 socket each,
1 16a garage,
32a cooker,
every other socket on 32a,
non rcd
light circits
and a 50a shower :|
Link to comment
tom there is nothing wrong with the ir its well within the 1meg allowed. this reading could indicate dampness in the walls, something plugged in.I would only start to worry when it gets to 2 megs
also nothing wrong with stranded
Link to comment
yer it just seemed a big drop for 2 years but like u say could be damp. i did my best to unplug everything but its always a pain when its not a new installation, i did p+n to earth just in case i missed something.
just the shower i recomended an rcbo, they are always tight though,
Link to comment
Did you test it 2 yrs ago when it was >200M? If not, I would be dubious about the reading. I have come across situations where the readings are falsely put down;) Nothing wrong with 59M though. Not brilliant but hey, the cables are donkeys yrs old.
Link to comment
Revved Up Sparky
Hi Tom, should'nt the lights go on an RCBO too ? (17th ed)--- or maybe the cables are buried deeper than 50mm etc.
Link to comment
Revved, ideally all circuits should be RCBO protected, only problem is, as you know, they cost a small fortune each.
AndyGuiness Drink
Link to comment
Archived
  • Create New...
