DONT STAY LURKING AS A GUEST,
CLICK HERE TO JOIN.
  • 0
crimps
tom1
Question
15 answers to this question
Heatshrink sleeving :)
AndyGuiness Drink
Link to comment
if its under a floor or in a wall therefore inaccessible you are going to need to provide some strain relief for the connection to be considered maintenance free. for my joints i would either use wagos in a choc box (hate chock boxes cable grips) or Ashley J803, J804 which i think are much easier to use.
Link to comment
Thought of the day. What is the BS for heat shrink sleeving over cable joints hidden or buried in walls or ceilings ?
I would not think there is a BS but a regulation to ensure you do it correctly but I am to lazy to look it up.
Batty
Link to comment
Indeed!Applaud SmileyApplaud SmileyApplaud Smiley
Guiness Drink
Link to comment
If it's non visual, several layers of self amalgamating tape. If visual then a couple of layers of heatshrink.
For non insulated crimps I use a layer of glue lined heatshrink on each crimp before final finishing as above.
I also stagger the crimps as per pic - ensures no contact between conductors if insulation should ever shrink back and makes the joint less bulky and can use a smaller diameter of heatshrink.
Link to comment
Love the free with first order SF level in the first pic :D
Link to comment
Archived
  • Create New...
