DONT STAY LURKING AS A GUEST,
CLICK HERE TO JOIN.
Countdown To Christmas!
  • 0
reg deviation
tom1
Question
9 answers to this question
Yes but shouldnt happen - bad design practice. 1 lighting circuit per RCD at the worst.
AndyGuiness Drink
Link to comment
They dont know their backsides from their elbows if thats the case.
AndyGuiness Drink
Link to comment
:^O
it is bad practise,
this forum is great, but it does make me lazy, the brb is upstairs and i have a fair idear where the reg is.
thanks for fast answer
Link to comment
The Godfather
on a split rcd board if they put both light circuits on the same rcd is it a deviation, or worth noteing thanks
Is this an Inspection question Tom?
Don
Link to comment
SPECIAL LOCATION
Deviation?
can be argues either way IMHO...
pivots around 314.1 (iii) page 39!
but you could argue if sufficient table lamps etc.. off socket circuits are available..
or emergency lighting in any really dark areas?
Then you have taken account of a 'single circuit fault' causing inconvenience!;\
Good practice IMHO no!
Bad practice IMHO YES!
would I do it... NO!:D;)
BUT!!!
I would check WHY the two light are on the same RCD...
My bet is they have a shared/borrowed neutral!:|;)
In which case it would be a deviation from 314.4,
and IMHO is a more dangerous practice due to risk of shock when trying to isolate one of the light circuits!:|:(
Link to comment
SPECIAL LOCATION
i had borrowed nutral suspision, its a 3 story house, light up and down,
i am adding light fitting minor work
If I were a betting man I would stick
Link to comment
Archived
  • Create New...
