DONT STAY LURKING AS A GUEST,
CLICK HERE TO JOIN.
Countdown To Christmas!
help with adding a circuit?
jl-heating
i am wanting to fit the customer a 12 Kw shower any tips ? i am thinking move a few circits round and use a re wirable and fit an shower rcd enclosure...
the install looks sound and well fitted, plenty of clips and routes are well planed.
all circuits are well below .5 ohm on ir so no problem there.
no continuity on any of the rings,
no main bonds to either gas or water.
all in all looks good. :)
Link to comment
I wouldn't bother with an RCD enclosure, connect your shower supply cable straight into the henley block, remember our moto: "if in doubt, link it out", and anyway the shower will have built in thermal protection. Looks like your well on top of that one, keep up the good work.
Link to comment
thanks riggy ... i thought a 30 amp jb would do the trick. i was struggling getting 6mm into the henly block..
just need to notify it and give the customer a cert for the work . :)
Link to comment
I'd suggest a bit of 1mm T+E on a 40amp mcb to be on the safe side.
Link to comment
T and E
lucky been T and E.... could just use Twin no earth! old colours... blend in more then!
Link to comment
You see I don't think a 40A MCB will run it, back to the moto: "if in doubt, link it out", and into the henleys, the customer won't thank you for a shoddy job!
Link to comment
T and E
My mate Seamus can supply used rubber insulated twin very reasonable like, it's a bit perished, and it's true there is some rodent damage, but it's never let me down...............other than the odd fire obviously, but don't we all have those?
Link to comment
I suppose, I could always drill the busbar and lug it on. Does that follow ye ol' link rule?
Link to comment
Now you're thinking, no inconvenience for the customer there - everybody's 'appy!Guiness Drink
Link to comment
Evans Electric
Must be getting late, I missed the subtle humour on this thread for a while, 12KW shower wired in 1.0mm indeed !!! We all know it should be 1.5mm that should carry 50 Amps.
Link to comment
ROTFWLApplaud Smiley
Link to comment
Robin Spark
Dont know why your being sarcastic for JLH.
The electrics have been perfectly fine for years!
Link to comment
green-hornet
0.75mm flex from one of the lighting circuits should be fine.
However make sure the flex is white, I have seen many a cowboy electrician do it in black, just goes to show they know not how to blend in.
Link to comment
After two showers you'd not be able to tell the difference!:coat
Link to comment
green-hornet
True, I would give you one of them scoobies but they appear to have gone awol.
For any person veiwing this forum for the first time we are indeed having a laugh, Of course you can run two 12kw shoers from a 1,5mm cable.
Link to comment
boltonsparky
Bell wire for showers allways works fine for me.
I use the colour changing type... it's white when you install it but changes to a nice cherry red colour when you switch the shower on.
You've heard of underfloor heating, right? Well the bell wire makes a good under plaster heating system.
I've never understood it but I allways get a feeling of guilt when I see a fire engine attending a call.
Link to comment
SPECIAL LOCATION
Couldn't we all just save a bit of money here and wire it in single's...
single conduit wire takes the Live...
bond the neutral at the shower onto the supply pipe....
bobs your aunties twin brother, lesbian best friend as they say!!:o:P
sort of TT shower installation;)BlushingO)
Link to comment
ooh we can say lesbian now!
must only be ****, ****, ****** and **** that are banned
:D
Link to comment
:D
:^O:^O:^O:^O:^O
Link to comment
Revved Up Sparky
52 amps full load current !!!!!!! what size is the cutout fuse ? .... :O)
Link to comment
your all spending far too much on cable and should be sacked.
all is needed is a single cable for supply you can get the newtral from the copper pipe nearest the shower i.e under the bath or airing cupboard using a crocodile clip. or if your feeling like a super spark use an earth clamp
Link to comment
As already stated in post #18 you mean? - this is the only method we have consensus on, can we agree that this is the future standard for 12kW showers then?
I'll ask Seamus if he has any rubber insulated singles - I assume size and colour aren't important?
Link to comment
Archived
  • Create New...
