DONT STAY LURKING AS A GUEST,
CLICK HERE TO JOIN.
  • 0
megger mft 1552
tom1
Question
9 answers to this question
red live
black neutral
green earth
i dont think it will work if you have black on earth, but ive never tried it
Link to comment
nice car bulmer ;)
Link to comment
i never really do it, usualy use the plug, did it the other day in the cu red phase, black nutral, green earth. looking at the instruction it says green and black to earth. i would have thought it would make no difference as the earth and nutral are combined on pme and for tt current would still flow
Link to comment
I use the red lead plugged into the lower socket on the MFT and the green or black lead plugged into the middle socket on the mft. (Using green or black lead obviously doesn't matter).
If using the switched probe, then don't use the red lead, but connect the probe instead.
Red lead/probe onto the line and other lead on the neutral.
There you go, clear as mud
Link to comment
nice car bulmer ;)
Cheers sellers, its a shame really because it looks like i'm going have to be selling it. Spent
Link to comment
it will probably have some test current flowing L-N, so if you put probe on earth, you will get false readings
Link to comment
nice one thanks. i did almost the same then except i had the earth lead conected as well
and the hi current loop test thats for testing non rcd circuits
Link to comment
Think it give the TRP error message.
Hi current for non RCD circuits with 2 leads
Link to comment
Archived
  • Create New...
