DONT STAY LURKING AS A GUEST,
CLICK HERE TO JOIN.
Countdown To Christmas!
  • 0
2391 practical eath loops on testboards
9johnp
Question
headbang
Can any one tell me if there are any pit falls to look out for when carring out earth loop tests on flat Db and main 3 Pase board on test rig in examGuiness Drink
Link to comment
1 answer to this question
You won't do the loop test at the board (Loop should be at end of all radials, or at each socket on the ring), the boards should have the covers on before you power up.
Make sure you switch over the two way switches and test both strappers on the two way lighting, and test the motor starter at the isolator side.
Link to comment
Archived
  • Create New...
