functional accuracy
spenceriles
Oct 5, 2009
7
hi guys
could you help with this one how would you check the functional accuracy of an insulation resistance tester
and why is a low value of resistance needed when carring out a cpc test
thanks spenc
1: calibration. can be done by using resistors of known values. or a pre made check box (avail on this forum)
2: R2 needs to be as low as possible to allow fuse/mcb to operate
Spence
as andy said you can purchase check box most people sell them RS etc or test from a known source.
In answer to your second question why you need a low value resistance is you will be reading as low as 0.05 ohms
