DONT STAY LURKING AS A GUEST,
CLICK HERE TO JOIN.
Countdown To Christmas!
Marking Cable
Apache
How do you make up cables when changing a DB/CU
33 members have voted
  1. 1. How do you make up cables when changing a DB/CU
    • Stickly Numbers
    • Cable Ties (colour co-ordinated)
    • Heat Shrink
    • Cable Ties (using multiple in patterns)
    • Notch Cables
    • Roman Numberals
    • Greek Alphabet
    • Blood Group and MHC
    • Disney Plasters
    • Other (please specify)
Apache
Not one to refuse a dare..........
Link to comment
Andy™
have a list next to DB of circuit numbers/descriptions which are cut into cable as roman numerals. and other various marks for feed/load etc (note: this is temp marking for me to ID them prior to connection)
if it still needs marked, i have a marker or some numbered tape,
Link to comment
Zeespark
Critchley markers.
AndyGuiness Drink
Link to comment
SPECIAL LOCATION
I tie ladies underwear around the conductors as appropriate........
I thought we all did?Blushing:|
Thats what Sandra told me anyway!?:_|:_|
I do hope he hasn't been telling me porky pies!!!!X(X(X(
I shall go and see him right now.....
Where's about is his big blue Pin thingy sticking !!!!!:|]:):o;\;\;\
Link to comment
SPECIAL LOCATION
Also may use a bit of PVC tape / perm marker pen!:|;)
Link to comment
I`m with our beloved Admin; scraping (usually with cutters) onto outer sheath.
However, I usually scribe roman numerals.
Unless there are MLXMVIII circuits; in which case I used different colours of tape; primarily when installing from scratch - i.e. a 130 final circuit dist panel; I used 4 colours of tape on both ends of each cable; in order to keep the idents straight.
KME
Link to comment
ROTFWL
Link to comment
green-hornet
I find it very difficult when panel wiring to mark using anything other than cable markers.
If its a house I use my side cutter to notch the cable, this is easy as in the house there are limited circuits maximum 12 on larger installs.
The cable markers I buy are a bit expensive at around
Link to comment
green-hornet
Here is a distribution board part through wiring
I mark with a unique code only I forget Blushing
Link to comment
Andy™
ive seen wiring like that before somewhere.....
is this the other half of it?
back to your pics though, looks like a good job. but why the TPN board?
Link to comment
green-hornet
This board is fed from the main db via 25mm cable with two other db fed from this one in 16mm each.
I prefer to use tpn boards mainly for the added space and if needed could still supply via 3phase.
Link to comment
Andy™
i agree on the extra space part! even with all those RCBO's, still loads of room
Link to comment
Archived
  • Create New...
