DONT STAY LURKING AS A GUEST,
CLICK HERE TO JOIN.
  • 0
Continuity test
L Plate
Question
Hello again,
what test instrument is most approriate for continuity testing for this installation ( 3 way lighting circuit ALTERNATIVE )
and why spacing for support for the cable is important ..in the workshop i normally have 15cm distance each clip because the more clips the more the installaion looks crowded ( clips ) any detailed idea about this PLEASE...
thanks again guys for your support
have a nice evening
Link to comment
2 answers to this question
Hello again,
and why spacing for support for the cable is important ..in the workshop i normally have 15cm distance each clip because the more clips the more the installaion looks crowded ( clips ) any detailed idea about this PLEASE...thanks again guys for your support
have a nice evening
General info about supporting cables and avoiding mechanical stresses can be found in Chapter 52
"selection & erection of wiring systems" pages 97 109.
Guidance Note 1 (Selection & erection) has some more specific info in Appendix G page 169 onwards...
basically it gives a few tables of max recommend spacings of cable clips for different environments.
Typical spacing 300mm Hoz / 400mm Vert for non -armoured cables with diameter between 9mm - 15mm.. but there is loads more table info!
Link to comment
low reading ohm meter with a test current of 200mA min.
if cables are not adequately supported, they will fall.
Link to comment
Archived
  • Create New...
