DONT STAY LURKING AS A GUEST,
CLICK HERE TO JOIN.
  • 0
notches and galv box lids
sellers
Question
Is this acceptable??
I'm rewiring just the sockets in a house with solid floors downstairs.
So under the upstairs floorboards there are loads more cables all running through notches. Is it ok for me to run my new cables through these and put galv box lids on?
Link to comment
See Andy's picture, thats how I'd do it if notches are already there, just do it , don't worry about it. Mechanical protection , no probs. Millions of houses like it.
Bang on, if the notches are already there, with the capacity to take your cables, drilling holes next to them makes no sense.
If there is no current route, obviously then it's drilling the joists as per regs.
Link to comment
Sellers, TLC do a better version of those safe plates compared to SF.
AndyGuiness Drink
Link to comment
AndyGuiness Drink
I know they do look a lot better, but its 1-2days delivery and that will be from monday. The first fix will be finnished tomorrow ready for plasterer on monday.
Link to comment
The only time I would put cables over a joist if it was a cottage with 3'' joists. Most houses you should be able to put holes through the joists. Do the job correctly.
Batty
Link to comment
Link to comment
Aint they gotta be 50mm deep now?? and youd have to work out grouping factors if you bunched them together whilst making your cable selection?? hth
Link to comment
have a look in the OSG gives a good diagram explaining it all. sorry cant remeber the page number.
Link to comment
7.3.1 OSG
A cable passing through a joist or ceiling support shall:
i) be at least 50mm from the top or bottom, as appropriate,
ii) have earthed amouring or an earthed metal sheath,
iii) be enclosed in earthed steel conduit or trunking, or
iv) be provided with mechanical protection sufficent to prevent penetration of the cable by nails, screws and the like. (Note: the requirement to prevent penetration is difficult to meet).
Link to comment
they should be 50mm deep, but if notches already there, adding more holes may do more damage to joists, so you could use them. not sure if galv box lids would be big enough (with them being round)
Link to comment
A galv box lid isnt the strongest of metal but it would take some hammering to get a nail through?
Link to comment
They did look like they would manage it, I could always use a bit of metal trunking cut and drilled to suit.
Link to comment
Link to comment
Damn you Andy!
Link to comment
Damn you Andy!
your slow today patch!
Link to comment
The picture links not working now the Pics compress themselves!
Link to comment
i thought it was just my computer - firefox updated about the same time
Link to comment
ffs andyc found that well quick lol good stuff
I was linked within the minute!
Link to comment
No - me too
Link to comment
Wheres Admin when you need him
Link to comment
you can buy things made for the purpose but its your call. Maybe some would say bit rough lol maybe not
cheers
Its not that mate, I will be mechanically protecting the existing cables whatever the weather. Now if its ok by the regs to put mine in while i'm there I may aswell, but if its not then I wont be. O)
Link to comment
Archived
  • Create New...
