DONT STAY LURKING AS A GUEST,
CLICK HERE TO JOIN.
  • 0
minor works
paul b b
Question
hello chaps,
if you add a light on to a circuit do you IR test the whole circuit or just the cable you install?
Link to comment
16 answers to this question
is L+N to earth ok on an EIC form?
Link to comment
is it ok to do l&n to earth on the lights after a consumer unit change so all the bulbs dont have to removed. if so, what would be written on the EIC (niceic version)? cheers wayne
Link to comment
entire circuit. normally L-N to earth though
Link to comment
l-n to earth... ok 2 questions
1. is this to protect things?
2. is this just a case of l-n in same connector block?
Link to comment
1: yes
2: just short L and N at some point. just whatever method is easiest. sometimes both into same croc clip, connector block, bit of wire etc
Link to comment
would you need to take all lamps out with a l-n to earth?
what do you put on the cert?
Link to comment
1: no. thats why you short L-N
2: reading for live - earth, LIM for live/live
Link to comment
ahhhh thanks andy.
i will add to your rep
Link to comment
so i can test at 500 with out having to take loads od gu10's out and unpluging the tranny
Link to comment
1: yes
2: see post 6
Link to comment
Thanks andy. is this 100% alright, ie infornt of an elecsa assesor.
Link to comment
yes. if he asks why L-n to E, just explain its to avoid damaging any load that may be connected to circuit
Link to comment
wont 500v blow the bulbs unless disconnected trannys bulbs etc or test at 250v ??
As Andy said..
Thats why you test with Live & Neutral joined and just go across (L-N) and (E),
so you don't damage any equipment vunerable to testing...
Page 83 on site guide..
10.3.3 Ins Res test
paragraph '2' under point 'b'
about half way down the page!;)
Link to comment
Good to do that on consumer unit changes when everthing is plugged in. I usually do it at 250v sorts out if you have anything faulty on circuit. Also on callouts for tripping RCD's that way it tells if its equipment or wiring.
Batty
Link to comment
with l-n shorted, there is no voltage accross the transformer (expect to earth, but transformers are DI anyway)
Link to comment
Archived
  • Create New...
