DONT STAY LURKING AS A GUEST,
CLICK HERE TO JOIN.
Stripping T&E
Andy™
well?
88 members have voted
  1. 1. well?
    • Snip end, pull earth
    • snip end, score sheath, pull earth
    • score sheath. dont pull earth
    • other
so how do you strip T&E
Link to comment
cheese wire method for me !!
Link to comment
Score around finished length, cut up middle (one side of sheath, not right through), peel sheath off. Simples ;)
Link to comment
I use side cutters, snip into end pull earth with side cutters snip end of sheath.
Trim to required length and strip with side cutters.
Not as neat as a stanly knife score but much faster.
On 10mm I score and do what Riggy does.
Link to comment
sometimes pull the earth but have a pair of ck automatic strippers that i use most of the time as get perfect lengths each time
Link to comment
Teeth - everytime :D
Link to comment
yours, or the (slave) animals you work with?! (anyone else think the vet has a rat ready to eat the insulation off the cables?)
Link to comment
Lightly score at finished length, put knife blade at end of cable and at 90 degrees between N and E angled slightly to E, slide knife up to cut, easy and neat.
Cheers Steve
Link to comment
I snip end and pull earth (For speed as mentioned above). Though doing this on 10mm twin tends to make a mess of earth so struggle to sleeve. So on 10mm twin I pull Line/phase/live/whatever the f*** you want to call it OR Neutral.
Link to comment
i was tought in college to lightly score the outer sheath at the desired length, then use a side cutters to cut the end to expose the earth, then pull the earth down to the score mark
Link to comment
  • 2 weeks later...
Cheers Steve
i dont want to be picky roys, but that aint 90 degrees!;\
Link to comment
those cutters look like they would struggle to cut paper!
Link to comment
  • 2 months later...
Read this ...... what do you guys recon???
Stripping TE by using the the cpc can stretch the unprotected cpc and lead to thinning of the cross sectional area, which in turn can affect the cables resistance.
Yes this is true but the csa will only change very slightly due to the force applied.
Lets suppose we have a 1m length of TE with 1mm cpc.
Using stress/strain relationship for copper ( Young's modulus) then a force of 10000Newtons will be required to stretch the cpc by 0.09mm ie 9 hundredths of a mm.!! The force can be equated back to a weight of 1000Kg.
So if a weight of 1000Kg is applied to the cpc then it stretches 0.09mm, this is hardly going to affect the cross sectional area of the cpc.
Tthe force required to strip the TE is most likely to be around 100N, ie 10Kg, this will stretch the cpc by 0.0009mm. This will result in the cpc cross section changing very very very very very slightly.
Therefore using the cpc to strip TE is hardly going to affect the cross section of the cpc when using it to strip the outer sheath. This in turn will not affect the cpc resistance either.
Link to comment
next time you strip T&E, once you have pulled the earth from the sheath, put it next to conductors and see how much it has grown
Link to comment
[quote name='Andy
Link to comment
try it with LSF twin and watch it grow loads.
Link to comment
I was about to say that. I remember doing this as an apprentice when I started working for a new company. I had been taught by the bloke I worked for previously to run the knife down the cable using the earth as a guide. One of the fellas at the company I started working for wasn't happy with that and made me swap to the snip\pull earth method. I did some testing, on the end of a full drum so it wasn;t pulling the earth from the other end of an offcut, and it does indeed stretch a fair distance.
Also called the cheese wire method ;)
Link to comment
Well......
Snip end; but grip the two halves with each hand, and pull apart, to score mark. slip line conductors from outer, and snip off.
Unless I have the "auto" strippers handy - then I just use them.....
Link to comment
Well......
Hi KME
What auto strippers do you use?? out of interest and would you recommend them??
Matt
Link to comment
The "CK" ones mate.
TBH, no, I wouldn`t get `em again. Fiddly, faffy, skin-nipping awkward things.
I`ll stick to the olde-fashionedy way, than you very much.
Link to comment
The "CK" ones mate.
These?
ShowImage.aspx?Type=3&File=T3942.jpg&Man=CEKA&Size=200&Save=17
Linky picture
Link to comment
These?
I've got some of those, they're pretty good, but I'd never try and use them to get the outer sheath off a T&E, not least because you'd not get the last inch or so off, and also I doubt you'd just slip the outer off anyway on many cables.
Link to comment
they say for 2.5, but they also work on 1.5 & 3c&e
and accoring to the website, they are no longer made
Link to comment
Archived
  • Create New...
