DONT STAY LURKING AS A GUEST,
CLICK HERE TO JOIN.
  • 0
Surge Protection
mapleford
Question
Hopefully an easy answer to this. Recently I'm being asked more and more to provide spurred sockets for flatscreen tvs on walls, (hidden behind). These tvs are worth a few quid and I've been wondering if there were a way to provide surge protection? Could put a plug in behind but that seems to be a bit of a hash to me, so I've been wondering if there is single socket outlet or fused spur type thing for this?
Link to comment
8 answers to this question
Just a quick question about this, are there any surge protectors that can be built into the CU like they have in Canada/US?
AndyGuiness Drink
Link to comment
and on further thought the filters dont last forever and i believe they indicate then they are no longer working, but you wont see that as they will be behind TV, so your best bet may be install a unit at the CU.
Link to comment
Zeespark,
Yes there are surge protectors that can be built into CUs & DBs. These are French; I'm not sure if they are available in the UK:
http://www.citel.fr/type_2_ac_power_surge_protectors-g-3-en.html
This subject came up with a client who has a property in Frnce, hence the French connection.
Here's a link to Merlin-Gerin / Schneider surge protection products:
http://surgelogic.com/literature/files/1312HO0101.pdf
Surge & lightning protection was a hot topic when I was working in Africa.
[edit] We often fitted DIN rail protectors in the CU / DB which were grounded to a local spike, spikes, or a mat. Further protection was by local protectors at the socket outlets themselves - pretty much the same as the MK sockets already noted in this thread.
Pyro.
Link to comment
Archived
  • Create New...
