DONT STAY LURKING AS A GUEST,
CLICK HERE TO JOIN.
Countdown To Christmas!
  • 0
Cu on it's side????
meady
Question
Need to fit a cu in a space which is only 300mm wide. The customer wants a dual rcd unit but the smallest I have found is 340mm. It will fit in if I side mount it but not sure if I should. Has anyone else fitted a cu like this to fit in a space and would it meet all regs? Personally I can't see a problem but I might be missing something.
http://www.meadelectricalservices.co.uk/
Link to comment
11 answers to this question
green-hornet
There would be nothing wrong with placing on its side, however it would look a bit odd.
If the customer is happy with this then it would be fine.
The only other alternative is to place one cu below another, splitting the circuits so as to avoid nuisance or inconveniant tripping.
Link to comment
Yeah that could work, so I'm assuming I would need to splitt the meter tails in a dp henly block. Would 16mm tails be ok for each board?
Link to comment
green-hornet
Depending on which boards you get you could put 25mm tails direct to db1 then use that as the main board to feed db2 via suitable breaker or direct link from the main terminals.
Personally I would use 25mm tails and 16mm earth for each board.
Link to comment
Andy™
nothing wrong with them on their side, expect it doesnt always looks right. functionally, its the same setup as a TPN board
Link to comment
mem do a stacked split load, not sure if its up to 17th yet. I'v used them as dual tarriff and rcbos. less tham 300mm i think, Is the wylex 5+5 any good thought it was just over 300mm. will try to have a look later.
Link to comment
PC Electrics
I've done this before in a cupboard with a split load board. Put all the labels on the correct way so they could be read normally.
Operationally there is no problem, just whether the client is happy from an aesthetic point of view.
Link to comment
Evans Electric
Could you try two small boards. Feed second board from a 30 amp way (say) and connect small circuits to it , Lights, smokes , a radial, outside lights.
Link to comment
NozSpark
Here's one I did earlier..
16th ed board, lower RCD fed from main isolator....
You could do it like this, but use RCBO's in the top CU!
Link to comment
the wylex boards are the ones I like to install, they are 340mm wide :-(
Link to comment
Power Ball
Funny enough I went to look at a job today and the CU is on it's side inside a 300mm kitchen unit looks odd but not a problem.
Chas
Link to comment
Very nice, good idea for such a narrow gap :-)
Link to comment
Archived
  • Create New...
