DONT STAY LURKING AS A GUEST,
CLICK HERE TO JOIN.
Countdown To Christmas!
wiring chandeliers
musicspark
musicspark
what singles would be suitable cable for inside metal chandeliers and table lamps etc? I get asked to do a lot of these,
I have been using 0.5 pvc heat resistant flex but sometimes there is little room inside the things for sheathed flex
Link to comment
Small oval flex?
AndyGuiness Drink
Link to comment
Why not strip the flex to create heat resistant singles?
Link to comment
would tri rated be any good?
It would, but the insulation's so thick you wouldn't be much better off.
Link to comment
I would use stripped heat resisting flex and feed some heat resisting sleeving over this if possible.
Batty
Link to comment
Archived
  • Create New...
