DONT STAY LURKING AS A GUEST,
CLICK HERE TO JOIN.
  • 0
Sky Signal
Badger
Question
does anyone have problems with no signal displayed when it rains?
Link to comment
18 answers to this question
it seems to happen when there's heavy cloud or bad weather
Quite normal, made even worse, with a poorly alligned dish or low reception area.
The Boys
Link to comment
spoke to a sky engineer a while back about this, he reckons if you turn your box off at the mains every night it stops this problem even when raining.
cant see why that would make a difference tbh
he did have a pink van though
Link to comment
The Boys agree (Although, why keep equipment on standby when your in bed?)
The Boys
Link to comment
only problem with turning off at the mains, is your guaranteed to forget to turn it back on before it starts to record
Link to comment
Assuming you have (or need) that option, of course Andy.
The Boys
Link to comment
yeah just like i did and missed the footy
doh!
Link to comment
Mine goes funny when it rains too Badge!
:D
Link to comment
hopefully ive sorted it, as we had a chimney taken down and some walls demolished a few weeks back, and the fact the meter showed a lslight drop ion signal, ive realinged the dish in the rain and everything is fine again (FOR NOW!)
Link to comment
then it rains refraction alters the angle of the satellite signal. If you align in the rain it won't be good when fine!
Link to comment
its dry at the moment, so well see :P
Link to comment
i once did a job in a very posh area and the home owner told me he had sky out to sort hazy picture quality and was told it was due to a very large mature tree (house size)in his grounds in line of sight from the dish(which for some reason was mounted about 6ft off the ground on a seperate garage wall, installer prob didnt have his big ladders!)... guy had tree cut down to the ground and shredded..... instantly made absolutely no difference to the picture quality...lol....
Link to comment
I have the same problem. No signal displayed when it rains?
Also the sound goes for no reason and the only way I can get it back is to switch of the box at the mains for five minutes.
headbang
Link to comment
my sky box randomly displays no signal, although its probably the box (often doesnt work and needs a minute to think about what its going to do, or not do)
Link to comment
it seems to happen when theres heavy cloud or bads weather
Link to comment
when it rains it creates 'white noise' which affects your signal to noise ratio
when its not raining and you get poor signal/loos of signal then this can be caused by 'solar flares' or 'sun spots'
if you have pixelation on only a few channels then your provider has used more than his allowable bandwidth for that 'stream' of channels.
turning your box completely off at night be it sky or cable then you are liable for extra problems
as this is the time they update software and communicate with the box
Link to comment
Thanks for the explanation :D
I turn mine off @ night
Link to comment
there is an easy way to update the software
Link to comment
Archived
  • Create New...
