DONT STAY LURKING AS A GUEST,
CLICK HERE TO JOIN.
  • 0
tt to tns to tncs
tom1
Question
funny... i have just done a simalar installation, same pipe (rod) in the ground and everything!.
it was still a TT though!
Link to comment
well my massive rod had a poor reading! .. but the ground looked very very dry... ended up putting a new rod in, out side in better soil!
Link to comment
Before the days where you could not smoke on site, I remember drilling through a floor and right into a gas pipe with a lit cigerette in my mouth.
My apprentice ran for cover, I just took another drag on my fag and shouted for the plumber.
Link to comment
id have a guess that it was TNS, but due to a high earth reading, they have made it TNCS. the link to see between neutral & sheath may possibly be the main earth to the sheath, or just to link the neutral to earth
Link to comment
ze 0.14 its got a pme sticker on it, does that make it tncs
its made TNCS by the big lump of copper between neutral and earth!
Link to comment
it has got a link between earth and neutral
and so its TNCS
Link to comment
has danny 7299 used this as a earth rod then?
Hell NO!!!
I put a couple of Rods in... but i did trow a 10mm onto it any way! just because it was below the C/U.
Link to comment
Hell NO!!!
as sparks2911 says above, it would still need earthing anyway
Link to comment
I may be way off here, but is that pipe not a capped off gas pipe?
Often seen when gas meter and gas main has been replaced, often with the new gas meter being placed in a box outside the property.
Just asking. :)
Link to comment
Just asking. :)
Seems plausible! :)
Link to comment
Just asking. :)
that was my thought as well GH!:D:)
Link to comment
i think it may well be now u mention it. yes that would make a lot of sense.
now all i need is a plumber to reconect it so i can avoid expensive bills this winter.
good job i left it in and did not try ripping it out:D
Link to comment
The " Massive rod" is a gas pipe , is it not.
Link to comment
Yes Deke, we have established that!
:D
Link to comment
if he has, it wont comply with 7671! (or... if its been cut in the street so its not part of the gas network, then im guessing it would be an acceptable rod?)
Link to comment
he said he put another rod in aswell so that should cover it
Just avoid the gas pipe underground!
:D
Link to comment
my brother drilled through a gas pipe once, it was an old lead one buried diagonaly in the wall:_|
ive drilled through a gas pipe.... pipe was somewhere it shouldnt have been, so first i knew was the gas coming from hole.... new build house which had just been decorated too....
Link to comment
Archived
  • Create New...
