DONT STAY LURKING AS A GUEST,
CLICK HERE TO JOIN.
Badger
Brick Built Pond and Electrical Cabinet
Badger
Heres some photos of our on going pond project from home, the pond is 6ft6 x 6ft6 x 2.5ft deep, brick lights have been installed although not fully working as yet all the consumer unit and associated electrical sockerts are fully installed now and tested ;)
Pic 1 + 2 shows ground works and concrete footings
piccy 3,4,5 shows main pool internal walls been built/constructed
piccy 6,7 shows outside brickwork being built/constructed
piccy 8,9 9a, 9b shows electrical setup
piccy 10 , 11 and 12
brick lights in outter wall
piccy 13
fountain and light underwater (low voltage ;) )
Share this post
Link to post
matt.leung
nice work...
Share this post
Link to post
Doc Hudson
Thank you Badger, nice set of photos.
Share this post
Link to post
androiduk2002
Very nice Badger..................
A man of many talents :Applaud:Applaud:Applaud.
1 Question ............ is that hose on the filter unit earth or neutral ? ROTFWLROTFWLROTFWL
Share this post
Link to post
Andy™
its the PME connection
Share this post
Link to post
Badger
[quote name='Andy
Share this post
Link to post
Badger
couple more photos as the pool has prgressed over the last week or so, plants have been put in, fish are now settled in, the pumps and filters are settled, the heron statue is installed :^O and the frog is now spitting water also put in are all the under water low voltage lighting as well.
Share this post
Link to post
Andy™
i notice how you installed a metalclad switch outside.... and then removed it....
but good work
probably be a few month before it gets finished though?
Share this post
Link to post
androiduk2002
Very nice job there Badger.
Its good to see projects as they progress.
We love photos :Applaud:Applaud
Share this post
Link to post
Badger
[quote name='Andy
Share this post
Link to post
Badger
the slabs will be got tomoz and the top of the pond should be finished by monday all being well weather permitting of course not much left to do now.
Share this post
Link to post
netblindpaul
You've got Water Hawthorn in there, very simple but stunning plant IMHO.
We have lost all of ours.
Paul
p.s. NOT a hint, I don't have enough time to look after our Koi pond at the mo!
Share this post
Link to post
Badger
Paul
the water hawthorn was bought late last year and placed in our old pond but has since been moved to the new large pool, although i dint have any koi apart from ghost koi in ours, we have moved all the frogs back in to our new pond from the old pond too, but now its taking shape its starting to look really stunning.
Share this post
Link to post
netblindpaul
trouble is frogs eat all the fish spawn so my late dad told me.
Share this post
Link to post
Badger
well i knew they can caused fish to suffercate when frogs are in mating season andy little buggers :^O but didnt realise they ate fish spawn, so that explains why we didnt have any baby fish then :(
Share this post
Link to post
Apache
Did you do all the block work?
Share this post
Link to post
Badger
i most certainly did why pache :o
Share this post
Link to post
M107
Nice job Badge
Share this post
Link to post
Badger
thankyou :)
Share this post
Link to post
Apache
freehand?
Share this post
Link to post
Badger
well, i used a string on the front and sides, but i havent finished it yet as the pointing needs to be finished of ;) but basically id never laid a brick in my life
Share this post
Link to post
Apache
I spotted the 'Brickie' :D
Was seeing if you would confess.
Looks a nice job :D
Share this post
Link to post
SPECIAL LOCATION
:Applaud:Applaud:Applaud:Applaud
GuinnessGuinnessGuinnessGuinness
Great pics Badge!:D
Share this post
Link to post
Badger
used the brickie on the internal blocks but because the cavity was so small only just enough for cables to pass through for lighting in brick work, i couldnt use the brickie on the faced brick work :( as i tried it,
Share this post
Link to post
Apache
I've got one. I can about glue blocks together but it saves me a load of mortar!
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
