In need of some advice, currently having a garage built at the side of my garden and obviously want it wired up. I haven't done much wiring myself, and have never planned a job like this. All connections & testing will be done by a qualified sparks but trying to save myself some money by running all the cables in advance.
In the garage I want 3-4 sockets, 1 light (possibly florescent?), Potential to put in a security light & electric door. The supply to the garage would be ran underground (SWA?) in total the run will be about 8-10 meters max.
Potential issues: The consumer unit is fitted under the stairs (plenty of space for another board if needed). The cable will have to be surface mounted (fitted just above skirting) until it gets outside due to concrete floor and work units, Also, where the cable will be going out of the house, I have Flow and Return (heating pipes) as well as gas that will be no more then 6 inches away (boiler sits above). Also have the condensing drain from the boiler straight next to where the cable will be coming out. If there weren't more problems, I also have the water main running down the side of the house which is buried roughly 12 inches deep.
So here's what I would like to know:
1. Cable type, size and dept that it'll need to be to feed what was described.
2. What type of consumer unit would be needed in the garage & what type of fuse would be needed in the existing board to allow for the new run.
3. Issues with cables being ran so close to central heating & gas pipes internally, water main & condensing drain outside.
Obviously I would have liked a proper sparks in to price up the job and tell me first hand how to do it, but the foundations have been laid and the brickies are coming on Monday and it's only just dawned on me I may actually need some power in there.
Any advice would be welcome and will provide more information if needed.
