Forums
New posts
Search forums
What's new
New posts
New media
New media comments
Latest activity
Media
New media
New comments
Search media
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Main Forums
Electrician Talk Forum
559.5.1.201 to 559.5.1.208 .........
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="phil d" data-source="post: 478437" data-attributes="member: 27126"><p>16mm boxes are a real pita at switches, I had one where the customer had just decorated, then decided to have some new dimmer switches fitted, they rang me when they discovered the switch wouldn't fit onto the existing box, fortunately I was able to peel the paper back enough to hack out the old box, make the hole deeper and get a deeper one in.</p><p></p><p>The one I always hated was the way councils wired their houses, all in singles, neutral looped at the light and live looped at the switch, no permanent live at the fitting, always a nuisance when fitting those fan/light units that were popular some years ago. </p></blockquote><p></p>
[QUOTE="phil d, post: 478437, member: 27126"] 16mm boxes are a real pita at switches, I had one where the customer had just decorated, then decided to have some new dimmer switches fitted, they rang me when they discovered the switch wouldn't fit onto the existing box, fortunately I was able to peel the paper back enough to hack out the old box, make the hole deeper and get a deeper one in. The one I always hated was the way councils wired their houses, all in singles, neutral looped at the light and live looped at the switch, no permanent live at the fitting, always a nuisance when fitting those fan/light units that were popular some years ago. [/QUOTE]
Insert quotes…
Verification
Post reply
Main Forums
