Forums
New posts
Search forums
What's new
New posts
New media
New media comments
Latest activity
Media
New media
New comments
Search media
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Main Forums
Electrical Inspection & Testing Forum
Asbestos in fuseboards.
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Ardet R" data-source="post: 462086" data-attributes="member: 30040"><p>To seal a loose fibre asbestos by spraying a sealant on to it, whilst it would help for the future, would not be safe because the spray would, at the time of use, distribute fibres into the air.</p><p></p><p>Painting a sealant on to an asbestos surface is less hazardous, but could still come with risks.</p><p></p><p>Not in this case (because the flash pad is meant to be non flammable, (amazingly)) but in general, painting an asbestos surface will, in the short term, prevent the release of fibres, subsequent coats of paint can be safely applied to the sealed surface for longer term containment.</p></blockquote><p></p>
[QUOTE="Ardet R, post: 462086, member: 30040"] To seal a loose fibre asbestos by spraying a sealant on to it, whilst it would help for the future, would not be safe because the spray would, at the time of use, distribute fibres into the air. Painting a sealant on to an asbestos surface is less hazardous, but could still come with risks. Not in this case (because the flash pad is meant to be non flammable, (amazingly)) but in general, painting an asbestos surface will, in the short term, prevent the release of fibres, subsequent coats of paint can be safely applied to the sealed surface for longer term containment. [/QUOTE]
Insert quotes…
Verification
Post reply
Main Forums
