Forums
New posts
Search forums
What's new
New posts
New media
New media comments
Latest activity
Media
New media
New comments
Search media
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Main Forums
Do-It-Yourself (DIY) Question & Answer Forum
Earthing Plastic Dimmer with Meta Plate Inside
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Bruspark" data-source="post: 486145" data-attributes="member: 20106"><p>If it needs to be earthed it will have a marked earth connection. If there isn't one and no different advice in the instructions then leave it alone. (May get hot in use so don't tape over or let cables press against it) .</p><p> </p><p></p><p>(Just because a dimmer heatsink (internal / inaccessible in this case) is metal it doesn't have to be live - in fact having it live is daft in so many ways.)</p></blockquote><p></p>
[QUOTE="Bruspark, post: 486145, member: 20106"] If it needs to be earthed it will have a marked earth connection. If there isn't one and no different advice in the instructions then leave it alone. (May get hot in use so don't tape over or let cables press against it) . (Just because a dimmer heatsink (internal / inaccessible in this case) is metal it doesn't have to be live - in fact having it live is daft in so many ways.) [/QUOTE]
Insert quotes…
Verification
Post reply
Main Forums
